node-red-contrib-gree-hvac 0.3.0
A Node-RED integration for controlling Gree smart air conditioners
npm install node-red-contrib-gree-hvac
NPM status Node-RED status Github Actions status
Provides a node for control Gree HVAC (Heating, ventilation, and air conditioning).
dashboard
[{"id":"ff9fe48d.da79d8","type":"debug","z":"fcc6883.6f01278","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":550,"y":700,"wires":[]},{"id":"3cfb9d5c.2adfc2","type":"gree-hvac","z":"fcc6883.6f01278","name":"AC","device":"","interval":"1","x":280,"y":640,"wires":[["ff9fe48d.da79d8"],["417b67b1.9d77d8","ff9fe48d.da79d8"]]},{"id":"fab8d073.bed76","type":"switch","z":"fcc6883.6f01278","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"power","vt":"str"},{"t":"eq","v":"mode","vt":"str"},{"t":"eq","v":"temperature","vt":"str"},{"t":"eq","v":"fanSpeed","vt":"str"},{"t":"eq","v":"swingVert","vt":"str"},{"t":"eq","v":"swingHor","vt":"str"},{"t":"eq","v":"health","vt":"str"},{"t":"eq","v":"blow","vt":"str"},{"t":"eq","v":"lights","vt":"str"},{"t":"eq","v":"powerSave","vt":"str"}],"checkall":"true","repair":false,"outputs":10,"x":430,"y":460,"wires":[["f36ddc6a.6a76d"],["ed7a4d0b.d3c85"],["7f2711eb.f70ff"],["b0f5ed20.f0dc4"],["bb2fd30d.6faed"],["426d8937.d2e9a8"],["58310de9.08b1c4"],["5be9ffdd.e9e11"],["429db373.92628c"],["29e1bfb7.c963c"]]},{"id":"f36ddc6a.6a76d","type":"ui_switch","z":"fcc6883.6f01278","name":"","label":"Power","tooltip":"","group":"5c569ec8.d608f","order":1,"width":"0","height":"0","passthru":false,"decouple":"true","topic":"power","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":610,"y":80,"wires":[["62c89d4e.1db264"]]},{"id":"429db373.92628c","type":"ui_switch","z":"fcc6883.6f01278","name":"","label":"Lights","tooltip":"","group":"5c569ec8.d608f","order":9,"width":"3","height":"1","passthru":false,"decouple":"true","topic":"lights","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":610,"y":560,"wires":[["62c89d4e.1db264"]]},{"id":"7f2711eb.f70ff","type":"ui_numeric","z":"fcc6883.6f01278","name":"","label":"Temperature","tooltip":"","group":"5c569ec8.d608f","order":2,"width":0,"height":0,"passthru":false,"topic":"temperature","format":"{{value}}","min":"23","max":"25","step":1,"x":630,"y":200,"wires":[["62c89d4e.1db264"]]},{"id":"bb2fd30d.6faed","type":"ui_dropdown","z":"fcc6883.6f01278","name":"","label":"Vertical swing ","tooltip":"","place":"Select option","group":"5c569ec8.d608f","order":6,"width":0,"height":0,"passthru":false,"options":[{"label":"Default","value":"default","type":"str"},{"label":"Swing in full range","value":"full","type":"str"},{"label":"Fixed top","value":"fixedTop","type":"str"},{"label":"Fixed mid-top","value":"fixedMidTop","type":"str"},{"label":"Fixed mid","value":"fixedMid","type":"str"},{"label":"Fixed mid-bottom","value":"fixedMidBottom","type":"str"},{"label":"Fixed bottom","value":"fixedBottom","type":"str"},{"label":"Swing bottom","value":"swingBottom","type":"str"},{"label":"Swing mid-bottom","value":"swingMidBottom","type":"str"},{"label":"Swing mid","value":"swingMid","type":"str"},{"label":"Swing mid top","value":"swingMidTop","type":"str"},{"label":"Swing top","value":"swingTop","type":"str"}],"payload":"","topic":"swingVert","x":640,"y":320,"wires":[["62c89d4e.1db264"]]},{"id":"62c89d4e.1db264","type":"rbe","z":"fcc6883.6f01278","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":830,"y":700,"wires":[["3cfb9d5c.2adfc2","ff9fe48d.da79d8"]]},{"id":"426d8937.d2e9a8","type":"ui_dropdown","z":"fcc6883.6f01278","name":"","label":"Horizontal swing ","tooltip":"","place":"Select option","group":"5c569ec8.d608f","order":5,"width":0,"height":0,"passthru":false,"options":[{"label":"Default","value":"default","type":"str"},{"label":"Full","value":"full","type":"str"},{"label":"Fixed left","value":"fixedLeft","type":"str"},{"label":"Fixed mid-left","value":"fixedMidLeft","type":"str"},{"label":"Fixed mid","value":"fixedMid","type":"str"},{"label":"Fixed mid-right","value":"fixedMidRight","type":"str"},{"label":"Fixed right","value":"fixedRight","type":"str"},{"label":"Full alt","value":"fullAlt","type":"str"}],"payload":"","topic":"swingHor","x":640,"y":380,"wires":[["62c89d4e.1db264"]],"info":"Controls the swing mode of the horizontal air blades (not available on all units)"},{"id":"b0f5ed20.f0dc4","type":"ui_dropdown","z":"fcc6883.6f01278","name":"","label":"Fan speed","tooltip":"","place":"Select option","group":"5c569ec8.d608f","order":4,"width":0,"height":0,"passthru":false,"options":[{"label":"Auto","value":"auto","type":"str"},{"label":"Low","value":"low","type":"str"},{"label":"Medium low","value":"mediumLow","type":"str"},{"label":"Medium","value":"medium","type":"str"},{"label":"Medium high","value":"mediumHigh","type":"str"},{"label":"High","value":"high","type":"str"}],"payload":"","topic":"fanSpeed","x":630,"y":260,"wires":[["62c89d4e.1db264"]]},{"id":"29e1bfb7.c963c","type":"ui_switch","z":"fcc6883.6f01278","name":"","label":"Power save","tooltip":"","group":"5c569ec8.d608f","order":10,"width":"3","height":"1","passthru":false,"decouple":"true","topic":"powerSave","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":630,"y":620,"wires":[["62c89d4e.1db264"]]},{"id":"417b67b1.9d77d8","type":"split","z":"fcc6883.6f01278","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":290,"y":460,"wires":[["fab8d073.bed76"]]},{"id":"ed7a4d0b.d3c85","type":"ui_dropdown","z":"fcc6883.6f01278","name":"","label":"Mode","tooltip":"","place":"Select option","group":"5c569ec8.d608f","order":3,"width":"0","height":"0","passthru":false,"options":[{"label":"Auto","value":"auto","type":"str"},{"label":"Cool","value":"cool","type":"str"},{"label":"Dry","value":"dry","type":"str"},{"label":"Fan only","value":"fan_only","type":"str"},{"label":"Heat","value":"heat","type":"str"}],"payload":"","topic":"mode","x":610,"y":140,"wires":[["62c89d4e.1db264"]]},{"id":"58310de9.08b1c4","type":"ui_switch","z":"fcc6883.6f01278","name":"","label":"Cold plasma","tooltip":"","group":"5c569ec8.d608f","order":7,"width":"3","height":"1","passthru":false,"decouple":"true","topic":"health","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":630,"y":440,"wires":[["62c89d4e.1db264"]]},{"id":"5be9ffdd.e9e11","type":"ui_switch","z":"fcc6883.6f01278","name":"","label":"X-Fan","tooltip":"","group":"5c569ec8.d608f","order":8,"width":"3","height":"1","passthru":false,"decouple":"true","topic":"blow","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":610,"y":500,"wires":[["62c89d4e.1db264"]]},{"id":"5c569ec8.d608f","type":"ui_group","z":"","name":"AC","tab":"168c092a.469d97","disp":true,"width":"6","collapse":false},{"id":"168c092a.469d97","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Example
example
Version: 0.3.0
Updated 1 year, 11 months ago
Rating: 4.4 5
26 in the last week
  • gree-hvac
  • gree-hvac-config
  • gree
  • hvac
