node-red-contrib-graphql-silvertrek 2.2.7
A Node-RED node to make GraphQL calls
npm install node-red-contrib-graphql-silvertrek
Platform Release NPM Codacy Badge
A NodeRed node to execute GraphQL Queries.
Change Log
Vers Changes
2.2.0 Really fix payload issue
2.1.2 Fix payload init issue
2.1.0 Bearer Token Authentication
2.0.1 Update dependencies (axios & mustache), fix node-red scorecard issues
2.0.0 GraphQL response is now on payload.graphql instead of replacing payload. This is a breaking change. Addresses #32
1.4.1 Bump follow-redirects to 1.14.8
1.4.0 improve debug, bump follow-redirects
1.3.0 bump axios to address CVE-2021-3749
1.2.0 Fix node not showing in palette, bump axios
1.1.0 Error Handling & Config Templates, showDebug & customHeaders, Bump axios
1.0.0 pass Authorization via msg.authorization, PR #21
0.0.6 Initial Release
GraphQL Nodes
Provides a GraphQL node to support queries and a configuration node called graphql-server-silvertrek.
graphql-server-silvertrek Configuration Node Fields
Name Use
Name Node Name
Endpoint URL to the endpoint
Token Bearer Token
graphql Function Node Fields
Name Use
Name Node Name
Endpoint Configuration Node Name
Query Query or Mutation template
Syntax Mustache / plain
Token Bearer Token
Show Debug Enable debug
Countries API Example
This example flow uses the node-red-contrib-graphql node to query the Countries API built by GitHub user Trevor Blades.
The example flow is in the file examples/countries.json. Import this file from the clipboard under the NodeRed menu Import > Clipboard. You'll drag the example flow onto NodeRed.
Example Flow
Edit graphql node
The GraphQL endpoint for is https://countries.trevorblades.com/. You can try it out here. Here's the graphql-node:
Edit GraphQL Node
GraphQL Output
This is the result sent to the debug window.
Example Flow Output
Authentication Example
A bearer token can be provided for authentication. This is an example using the GitHub GraphQL API which is documented here.
Github Flow
Config Node Token
If you have an token with a long life, you can provide the token in the graphql-server-silvertrek configuration node. For GitHub, user your GitHub PAT.
Github Config
You can also provide the token in the graphql node. This is useful if a prior node performs the authentication and returns the token to be used for a limited session.
GitHub GraphQL
Custom Headers
You can provide custom headers to the GraphQL node by attaching a customHeaders key to the msg and passing that to the GraphQL node. Here's an example that sets the content-type and a bearer token.
Custom Headers
Templates and Variable Use
There are two template flavors:
  1. Plain
  2. Mustache
At the bottom of the template text area, you must select between plain or mustache template.
If you select mustache, your template will be processed by Mustache with the message's payload as an argument. I.e.
submitted_template = mustache("template in text area", msg.payload)
If you select plain, the template is left as it is.
Template variables
You can add GraphQL query variables to the submitted query by defining them in the msg.variables property. Your variables will be passed over to the GraphQL query.
For example, if you define
type Response {
  ok: boolean
input doSomethingInput {
  myVar: String
type Mutation {
  doSomething(input: doSomethingInput!): Response
you can pass the messageInput parameter as such in Node-Red msg:
msg.variables = {
  "input": {
    "myVar": "myValue"
it will be added to the GraphQL query:
query: `mutation doSomething($input: messageInput!) {
  doSomething(input: $input) {
    ok
variables: {
  input: {
    myVar: "myValue"
When using a scalar type like JSON, the entire payload can conveniently be passed as an input parameter:
scalar JSON
type Response {
  ok: boolean
input payloadInput {
  payload: JSON
type Mutation {
  doSomething(input: payloadInput!): Response
In node-red flow, prepare payloadInput variables:
msg.variables = {
  "input": {
    "payload": msg.payload
which will results in
query: `mutation doSomething($input: payloadInput!) {
    ok
variables: {
  input: {
    myVar: { whatever: "was in you msg.payload", val: 5, bool: true }
The execution will return the value in:
msg.payload.doSomething
object.
Outputs
payload is loaded with the output of the Query or Mutation. If the Query is named doSomething, the results of the query will be in payload.doSomething.
//msg.payload is:
  doSomething: {
    ok: true
Version: 2.2.7
Updated 2 years ago
7 in the last week
  • graphql-server-silvertrek
  • graphql-silvertrek
  • graphql
