node-red-contrib-graphql-server 0.2.1
A set of nodes to run a local GraphQL Server in Node-RED
npm install node-red-contrib-graphql-server
A set of nodes for Node-RED to run a local GraphQL Server. The server uses the javascript reference implementation of the GraphQL specification.
To install the stable version use the Menu - Manage palette option and search for node-red-contrib-graphql-server , or Run the following command in your Node-RED user directory - typically ~/.node-red
Note: Requries NodeJs version 11.15 or higher
npm install node-red-contrib-graphql-server --engine-strict
This node bundle helps you build a fully functional GraphQL Server for your application. It uses the approach of Schema-First and delegates resolution of the queries to Node-RED flows. The bundle includes 3 nodes which together provide a full implementation of GraphQL specifications:
  • graphql-in : Creates a GraphQL server endpoint at the defined path supporting both query and mutation operations. The endpoint serves both GET and POST requests by default.
  • graphql-out: Sends responses back for requests recieved from a GraphQL In node.
  • graphql-schema: Configuration to define a GraphQL schema.
  • graphql-subscriptionserver : a graphql subscription server implementation using PubSub
Summary of features
  • Uses Node-RED httpNode which means it inherits any middlewares, security,etc. you may have.
  • Includes Dataloader which enables efficient query implementation for nested operations inherent to any GraphQL server.
  • There are 3 modes to choose from to determine how you plan to resolve queries. Please read the docs to understand the differences.
  • includes a GraphQL Schema Visual editor, and GraphQL Voyager builds ! (I may remove those builds from future nodes but those are great for learning GraphQL if you are new)
  • includes a GraphQL Playground (previously I used GraphiQL) - the Playground enables you to test your query, mutation operations and interact with the server. The Playground also supports subscriptions!
  • Experimental feature to automatically resolve Pagination in your schema. This is supporting the unofficial GraphQL Cursor Pagination Specs
  • Subscription Server implementation based on graphql-subscriptions using MQTT for PubSub which means you can use the out of box MQTT nodes with it.
  • The data in msg.graphql includes everything you may need to resolve the query such as operation details, result of previous query, arguments passed to the query, reference to the root of the query,etc.
How to use it
  1. Define a GraphQL schema using GraphQL Schema Language. If you are new to GraphQL use the included Visual GraphQL-Editor and it will generate a schema for you. Start by a simple schema. A simple schema might look like this:
type Query{
	posts : [Post!]
type Post{
	title : String!
	body : String!
schema{
	query: Query
  1. Configure how you plan to resolve the queries and mutations, and decide whether to use Dataloader
  2. Depending on what you choose for Resolvers mode and create flows which resolves your operations. Resolvers mode controls what messages will be sent to the output port of the GraphQL In node. The flow typically starts with a Switch node which branches out to each type of operation to resolve. There are many fields sent with the message to help you determine how to return the data in msg.graphql. It is completely up to you to define the flow resolving the operations. The resolvers flow typically interacts with a backend database , or retrieve data from external services and returns the results back to clients.
  3. Return the results to client using GraphQL Out node.
Example flow
The example flow comes from the original Facebook Starwars implementation and using data from swapi.
Starwars Flow
You can find the example flow in the examples folder of the node. Import the example from Node-RED using the Import function or Copy the below example flow below
[{"id":"b97ca9cc.1d71d8","type":"graphql-in","z":"45220d0b.f233a4","path":"/graphql","method":"getandpost","schema":"6c0760fa.703ea","graphi":true,"timeout":"20000","resolverstype":"nonscalar","resolvers":[],"usedataloader":true,"useSubscriptionServer":true,"subscriptionsPath":"/subscriptions","name":"","x":215,"y":300,"wires":[["a4bcf985.7948b8"]]},{"id":"3dbeb01f.1859e","type":"graphql-out","z":"45220d0b.f233a4","name":"","output":"payload","outputType":"msg","returnformat":"nochange","return":"asis","returnarrayindx":0,"x":1025,"y":475,"wires":[]},{"id":"7596de41.2034e","type":"link out","z":"45220d0b.f233a4","name":"","links":["a04aa07d.67b8b"],"x":1000,"y":335,"wires":[]},{"id":"a04aa07d.67b8b","type":"link in","z":"45220d0b.f233a4","name":"","links":["7596de41.2034e"],"x":295,"y":520,"wires":[["3ef20979.6e3026"]]},{"id":"2e9bddfa.e0a1a2","type":"graphql-out","z":"45220d0b.f233a4","name":"","output":"payload","outputType":"msg","returnformat":"nochange","return":"asis","returnarrayindx":0,"x":1030,"y":550,"wires":[]},{"id":"6f6ceb17.6ac9d4","type":"group","z":"45220d0b.f233a4","name":"download or use starwars data from cache if available","style":{"label":true},"nodes":["f6ff1bb6.dccc38","7c6b8368.3b7e6c","e24e585c.2e2cd8","a4bcf985.7948b8","22963952.9a0156"],"x":324,"y":219,"w":622,"h":162,"info":"try different queries using the Playground\nfor example\n\n```\nquery{\nfilm(id: 4){\n  title\n  director\n  producer\n  characters{\n    name\n    gender\n    height\n    homeworld {\n      name\n      population\n      gravity\n      terrain\n    }\n  }\n  species{\n    name\n    eye_colors\n    language\n  }\n}\n}\n```"},{"id":"f6ff1bb6.dccc38","type":"change","z":"45220d0b.f233a4","g":"6f6ceb17.6ac9d4","name":"","rules":[{"t":"set","p":"url","pt":"msg","to":"\"https://raw.githubusercontent.com/nileio/node-red-contrib-graphql-server/master/examples/starwars_data/\"&$lowercase(graphql.return.type)&\"s\"&\".json\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":260,"wires":[["7c6b8368.3b7e6c"]]},{"id":"7c6b8368.3b7e6c","type":"http request","z":"45220d0b.f233a4","g":"6f6ceb17.6ac9d4","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":725,"y":260,"wires":[["e24e585c.2e2cd8"]]},{"id":"e24e585c.2e2cd8","type":"change","z":"45220d0b.f233a4","g":"6f6ceb17.6ac9d4","name":"cache","rules":[{"t":"set","p":"cache[msg.graphql.return.type]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":260,"wires":[["7596de41.2034e"]]},{"id":"a4bcf985.7948b8","type":"switch","z":"45220d0b.f233a4","g":"6f6ceb17.6ac9d4","name":"","property":"$lookup($flowContext(\"cache\"),graphql.return.type)","propertyType":"jsonata","rules":[{"t":"null"},{"t":"nnull"}],"checkall":"true","repair":false,"outputs":2,"x":400,"y":300,"wires":[["f6ff1bb6.dccc38"],["22963952.9a0156"]]},{"id":"22963952.9a0156","type":"change","z":"45220d0b.f233a4","g":"6f6ceb17.6ac9d4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$lookup($flowContext(\"cache\"),graphql.return.type)","tot":"jsonata"},{"t":"set","p":"usedCached","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"vb","pt":"msg","to":"[{\"Film\":{\"characters\":\"persons.films\"}}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":340,"wires":[["7596de41.2034e"]]},{"id":"cedc6b6d.8da468","type":"group","z":"45220d0b.f233a4","name":"starwars query resolvers","style":{"label":true},"nodes":["f8b88c35.b417f","275d82a5.38c92e","cf1d900f.91c12","f18d54e0.b6c318","208b9510.427b7a","3ef20979.6e3026"],"x":329,"y":394,"w":612,"h":237},{"id":"f8b88c35.b417f","type":"change","z":"45220d0b.f233a4","g":"cedc6b6d.8da468","name":"filter by root args","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[id=$number($$.graphql.args.id)]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":805,"y":435,"wires":[["3dbeb01f.1859e"]]},{"id":"275d82a5.38c92e","type":"change","z":"45220d0b.f233a4","g":"cedc6b6d.8da468","name":"filter by parent object","rules":[{"t":"set","p":"payload","pt":"msg","to":"$exists(graphql.parent.payload.$eval($$.graphql.fieldName))? \t($r:=$type(graphql.parent.payload.$eval($$.graphql.fieldName))=\"array\"?[payload[id in $$.graphql.parent.payload.$eval($$.graphql.fieldName)]]:\tpayload[id in $$.graphql.parent.payload.$eval($$.graphql.fieldName)];\t$exists($r)?$r:{})\t:\t($r:=$type($eval($$.graphql.parent.fieldName))=\"array\"?\t\t[payload[graphql.parent.payload.id in $eval($$.graphql.parent.fieldName)]]:\tpayload[graphql.parent.payload.id in $eval($$.graphql.parent.fieldName)];\t$exists($r)?$r:{})\t\t\t\t\t\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":815,"y":520,"wires":[["2e9bddfa.e0a1a2"]]},{"id":"cf1d900f.91c12","type":"switch","z":"45220d0b.f233a4","g":"cedc6b6d.8da468","name":"Dataloader?","property":"graphql.config.useDataLoader","propertyType":"msg","rules":[{"t":"false"},{"t":"true"}],"checkall":"false","repair":false,"outputs":2,"x":610,"y":560,"wires":[["275d82a5.38c92e"],["f18d54e0.b6c318"]]},{"id":"f18d54e0.b6c318","type":"change","z":"45220d0b.f233a4","g":"cedc6b6d.8da468","name":"filter by parent array","rules":[{"t":"set","p":"payload","pt":"msg","to":"$exists(graphql.parent.payload.$eval($$.graphql.fieldName))? \t$map(graphql.parent.payload,function($v,$i){\t($r:=$$.graphql.return.isArray?[payload[id in $v.$eval($$.graphql.fieldName)]]:payload[id in $v.$eval($$.graphql.fieldName)];\t$exists($r)?$r:{})\t})\t\t:\t$map(graphql.parent.payload,function($v,$i){\t\t($r:=$type($eval($$.graphql.parent.fieldName))=\"array\"?\t\t[payload[$v.id in $eval($$.graphql.parent.fieldName)]]:\tpayload[$v.id in $eval($$.graphql.parent.fieldName)];\t$exists($r)?$r:{})\t\t})\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$count(graphql.parent.payload)>1?[payload]:[[payload]]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":815,"y":590,"wires":[["2e9bddfa.e0a1a2"]]},{"id":"208b9510.427b7a","type":"switch","z":"45220d0b.f233a4","g":"cedc6b6d.8da468","name":"args?","property":"graphql.args","propertyType":"msg","rules":[{"t":"hask","v":"id","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":595,"y":470,"wires":[["f8b88c35.b417f"],["3dbeb01f.1859e"]]},{"id":"3ef20979.6e3026","type":"switch","z":"45220d0b.f233a4","g":"cedc6b6d.8da468","name":"Root Query?","property":"graphql.isRoot","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"false","repair":false,"outputs":2,"x":425,"y":520,"wires":[["208b9510.427b7a"],["cf1d900f.91c12"]]},{"id":"6c0760fa.703ea","type":"graphql-schema","name":"Star Wars","schema":"type Query{\n\tperson(\n\t\tid : ID!\n\t) : Person\n\tpeople(\n\t\tlimit : Int\n\t) : [Person!]!\n\tfilm(\n\t\tid : ID!\n\t) : Film\n\tfilms(\n\t\tlimit : Int\n\t) : [Film!]!\n\tstarship(\n\t\tid : ID!\n\t) : Starship\n\tstarships(\n\t\tlimit : Int\n\t) : [Starship!]!\n\tvehicle(\n\t\tid : ID!\n\t) : Vehicle\n\tvehicles(\n\t\tlimit : Int\n\t) : [Vehicle!]!\n\tspecie(\n\t\tid : ID\n\t) : Specie\n\tspecies(\n\t\tlimit : Int\n\t) : [Specie!]!\n\tplanet(\n\t\tid : ID!\n\t) : Planet\n\tplanets(\n\t\tlimit : Int\n\t) : [Planet!]!\n}\n\n#A Person is an individual person or \n#character within the Star Wars universe.\ntype Person{\n\tid : ID!\n\tbirth_year : String!\n\teye_color : String!\n\tfilms : [Film!]\n\tgender : String!\n\thair_color : String!\n\theight : Float!\n\thomeworld : Planet\n\tmass : String!\n\tname : String!\n\tskin_color : String!\n\tcreated : DateTime!\n\tedited : DateTime!\n\tspecies : [Specie]\n\tstarships : [Starship!]\n\tvehicles : [Vehicle!]\n}\n\ntype Film{\n\tid : ID!\n\tcharacters : [Person!]\n\tcreated : DateTime!\n\tdirector : String!\n\tedited : DateTime!\n\tepisode_id : ID!\n\topening_crawl : String!\n\tplanets : [Planet!]\n\tproducer : String!\n\trelease_date : DateTime!\n\tspecies : [Specie!]\n\tstarships : [Starship!]\n\ttitle : String!\n\tvehicles : [Vehicle!]\n}\n\nscalar DateTime\n\ntype Planet{\n\tid : ID!\n\tclimate : String!\n\tcreated : DateTime!\n\tdiameter : String!\n\tedited : DateTime!\n\tfilms : [Film!]\n\tgravity : String!\n\tname : String!\n\torbital_period : String!\n\tpopulation : String!\n\tresidents : [Person!]\n\trotation_period : String!\n\tsurface_water : String!\n\tterrain : String!\n\tspecies : [Specie!]\n}\n\ntype Specie{\n\tid : ID!\n\taverage_height : String!\n\taverage_lifespan : String!\n\tclassification : String!\n\tcreated : DateTime!\n\tdesignation : String!\n\tedited : DateTime!\n\teye_colors : String!\n\thair_colors : String!\n\thomeworld : Planet\n\tlanguage : String!\n\tname : String!\n\tpeople : [Person!]\n\tfilms : [Film!]\n\tskin_colors : String!\n}\n\ntype Starship{\n\tid : ID!\n\tMGLT : String!\n\tcargo_capacity : String!\n\tconsumables : String!\n\tcost_in_credits : String!\n\tcreated : DateTime!\n\tcrew : String!\n\tedited : DateTime!\n\thyperdrive_rating : String\n\tlength : String!\n\tmanufacturer : String!\n\tmax_atmosphering_speed : String!\n\tmodel : String!\n\tname : String!\n\tpassengers : String!\n\tfilms : [Film!]\n\tpilots : [Person!]\n\tstarship_class : String!\n}\n\ntype Vehicle{\n\tid : ID!\n\tcargo_capacity : Int!\n\tconsumables : String!\n\tcost_in_credits : String!\n\tcreated : DateTime!\n\tcrew : Int!\n\tedited : DateTime!\n\tlength : String!\n\tmanufacturer : String!\n\tmax_atmosphering_speed : String!\n\tmodel : String!\n\tname : String!\n\tpassengers : Int!\n\tpilots : [Person!]\n\tfilms : [Film!]\n\tvehicle_class : String!\n}\n\ntype Subscription{\n\tnewFilms : Film!\n}\nschema{\n\tquery: Query,\n\tsubscription: Subscription\n}","pagination":false,"cursorField":""}]
I also included another more advanced example which uses a sqlite version of the chinook database The database is located in the example folder of the node. The example flow is a more advanced example using Pagination.
Version: 0.2.1
Updated 6 years ago
Rating: 3.7 3
29 in the last week
  • graphql-in
  • graphql-out
  • graphql-schema
  • graphql
  • server
  • http-in
  • node-red-contrib-graphql-server
