node-red-contrib-gpt-engineer-api 1.0.1
adds Node to call gpt-engineer through ssh connection and cli commands
npm install node-red-contrib-gpt-engineer-api
General note
This node is a wrapper allowing to interact with separate gpt-engineer installation through ssh connection and cli commands.
Requirements
  • your own openai API key
  • separate gpt-engineer installation with ssh server (may be on different server form the node-red server) docker build -t mygptengineer ./docker/ --load docker-compose up -d you can now connect to gpt-engineer with ssh sshuser@localhost -p 2222
  • or if you are checking connection from docker container ssh sshuser@gpt-engineer -p 22
to run gpt-engineer locally you can now use docker run -it --rm -e OPENAI_API_KEY="YOUR OPENAI KEY" -v ./your-project:/project gpt-engineer
usage
payload.topic - 'prompt' | 'response'
  • prompt - means initial prompt to be placed in prompt file that gpt-engineer expects
  • response - means that current message is ment as response to gpt-engineer interactive question
payload.value
  • in case of topic = prompt, the payload.value should contain the prompt string
  • in case of topic = response, the payload.value should contain the cli question text response
payload.projectName
  • string containing unique project name, as the files will be generated on the gpt-engineer server
try using example
SECURITY Note:
  • this node is not meant to be used on shared hosting, or shared node-red environments, it may leave openai key in plain text in gpt-engineer server logs as this uses cli to execute gpt-engineer
Version: 1.0.1
Updated 3 years, 3 months ago
1 in the last week
  • gpt-engineer
  • gpt-engineer-config
  • openai
  • chatgpt
  • gpt-engineer
  • cli
