node-red-contrib-govee-bt-client 1.0.0
Using noble.js, via govee-bt-client, continuously scans advertisements from Govee BLE Thermometer & Hygrometer devices.
npm install node-red-contrib-govee-bt-client
This Node-Red module contains the "Govee Device" node that continously scans for broadcast messages from Govee BLE devices, using the govee-bt-client module (which uses the noble library).
To install this module use Node-Red GUI installer or console command:
This module requires the govee-bt-client module and noble library which will be installed automatically. Take note about the requirements when running on linux.
Output message: msg.payload contains the decoded information from the Govee device, e.g.:
  "uuid":"a1b2c3d4e5z6",
  "address":"00:1b:44:11:3a:b7",
  "model":"GVH5075_E79E",
  "battery":100,
  "humidity":68.6,
  "tempInC":20.2686,
  "tempInF":68.48348,
  "rssi":-75
Version: 1.0.0
Updated 5 years, 10 months ago
5 in the last week
  • Govee Device
  • ble
  • bluetooth
  • nodered
  • sensor
  • temperature
  • humidity
  • govee
