node-red-contrib-govee 1.0.1
Node-RED nodes for Govee smart light control over LAN
npm install node-red-contrib-govee
Node-RED nodes for controlling Govee smart lights over the local network (LAN). No cloud API or account required — communication happens directly via UDP multicast.
Or install via the Node-RED Palette Manager: search for node-red-contrib-govee.
Node: Govee Light
A single node that both sends commands to and receives status updates from a Govee light on your local network.
Setup
  1. Drag the Govee Light node into your flow
  2. Double-click it and press the 🔍 scan button to discover devices on your LAN
  3. Select your device from the dropdown
  4. Deploy
Sending Commands (Input)
Send a msg.payload to control the light:
Payload Type Description
true / false boolean Turn light on / off
{ power: true } object Turn light on / off
{ brightness: 75 } object Set brightness (0–100)
{ kelvin: 4000 } object Set color temperature (2000–9000 K)
{ rgb: [255, 0, 128] } object Set color as RGB array
{ rgb: "#ff0080" } object Set color as hex string
{ hsl: [300, 255, 128] } object Set color as HSL array
Multiple properties can be combined in a single payload:
{ "power": true, "brightness": 80, "kelvin": 4000 }
Note: kelvin and rgb/hsl are mutually exclusive — if kelvin is set, rgb and hsl are ignored.
Receiving Status (Output)
The node emits a msg.payload whenever the device status changes:
  "power": true,
  "brightness": 80,
  "color": [255, 0, 128],
  "kelvin": 0
Requirements
  • Node.js ≥ 18.0.0
  • Node-RED ≥ 4.0.0
  • Govee light must be on the same LAN (UDP multicast)
MIT
Version: 1.0.1
Updated 3 months, 3 weeks ago
6 in the last week
  • govee-light
  • node-red-contrib
  • govee
  • smart-light
  • iot
  • lan
