node-red-contrib-gotify-notifications 1.0.2
Node-RED nodes to send notifications to a Gotify server
npm install node-red-contrib-gotify-notifications
Node-RED nodes for working with a Gotify self-hosted notification server.
This module provides:
  • Gotify Server config – holds the base URL and optional port of your Gotify server.
  • Gotify Apps config – holds App tokens, used for sending notifications.
  • Gotify Clients config – holds Client tokens, used for subscribing to notifications.
  • Gotify Send node – publishes notifications to a Gotify App.
  • Gotify Subscribe node – listens for incoming notifications from a Gotify server.
There are other nodes for Gotify available, but I created this one to make the setup of servers, applications, and clients more user-friendly and also to simplify the use of message extras like click URL, bigImage, and markdown formatting.
From your Node-RED user directory (usually ~/.node-red), run:
Restart Node-RED and the nodes will appear in the Gotify category of the palette.
Configuration Nodes
Gotify Server
Defines the base URL of your Gotify server.
  • Example: http://gotify.lan or https://example.com/gotify.
  • Optional Port field can be left empty if using standard ports (80/443).
    Do not include /stream or /ws in the URL.
Gotify Apps
Represents a Gotify App token.
  • Used by the Send node to publish messages.
  • Tokens can be created in the Gotify Web UI under Apps → Create Application.
Gotify Clients
Represents a Gotify Client token.
  • Used by the Subscribe node to listen for incoming messages.
  • Tokens can be created in the Gotify Web UI under Clients → Create Client.
Gotify Send Node
The gotify-send node publishes messages to a Gotify App.
Gotify Send Editor
Options
  • Server: Select a Gotify Server config.
  • App: Select a Gotify App token config.
  • Title: Default title (overridden by msg.title).
  • Message: Default message (overridden by msg.payload or msg.message).
  • Priority: Default priority (overridden by msg.priority).
  • Markdown: Boolean toggle. If true, message will be sent as text/markdown; if false, text/plain. Overridden by msg.markdown.
  • Big Image URL: Optional image to display (overridden by msg.bigimage).
Input message fields
  • msg.payload or msg.message → message content
  • msg.title → optional message title
  • msg.priority → priority (integer)
  • msg.markdown → boolean, true = Markdown, false = Plain text
  • msg.bigimage → optional image URL
Gotify Subscribe Node
The gotify-subscribe node connects to a Gotify server and listens for notifications in real time using WebSockets.
Gotify Subscribe Editor
Options
  • Client: Select a Gotify Client token config.
Output
Each received Gotify message is sent as an object on msg.payload. Example shape:
  "payload": {
    "id": 123,
    "appid": 4,
    "message": "Hello from Gotify!",
    "title": "Greeting",
    "priority": 5,
    "extras": { },
    "date": "2025-09-20T12:34:56Z"
Status indicators
  • green dot → connected
  • red ring → disconnected (auto-reconnect after 5s)
  • red ring + error → connection error
Tokens: App vs Client
Gotify has two types of tokens, and it’s important to use the right one:
  • App tokens → used by Send node (publishing).
  • Client tokens → used by Subscribe node (listening).
    Using an App token with Subscribe will result in “unauthorized” errors.
MIT
Version: 1.0.2
Updated 1 year, 2 months ago
  • gotify-server
  • gotify-send
  • gotify-apps
  • gotify-clients
  • gotify-subscribe
  • gotify
  • notifications
