node-red-contrib-gotify-notification 1.1.6
A node-red module for sending and subscribing to notifications from Gotify
npm install node-red-contrib-gotify-notification
Node-RED Gotify Integration
Node-RED Gotify
A comprehensive module for Node-RED facilitating the sending and receiving of notifications via Gotify.
Instalation
In order to install the module run
Publish Node Configuration
Publish Node
Configuration:
  • Override: Determines if the title, message, priority, and extras properties from incoming messages should be overwritten.
  • Title: Specifies the notification title.
  • Message: The main text of the notification.
  • Priority: Sets the notification's priority level.
  • Extras: Additional data for the notification, formatted as JSON.
Workflow
The publish node can be integrated at any point in your workflow.
Inputs
The node accepts inputs from the msg. object. Ensure override is disabled to utilize this feature.
Example msg Object
  "message": "Example Message",
  "title": "Example Title",
  "priority": 5,
  "extras": {
    "my_extra_parameter": "Parameter"
Outputs
After sending a notification, the node outputs the notification details as a JSON object in msg.gotify.
Subscribe Node Configuration
Subscribe Node
Configuration:
  • Server: The target server for subscription.
Workflow
This node can be placed at any suitable point in your workflow.
Outputs
Upon receiving notifications, the node outputs the data as a JSON object in msg.
Example msg Object for a Notification
  "id": 1,
  "appid": 1,
  "message": "Some message",
  "title": "Some title",
  "priority": 0,
  "date": "2025-01-23T18:16:08.991165343Z"
Version: 1.1.6
Updated 1 year, 6 months ago
License: GPL-3.0
9 in the last week
  • gotify-push
  • gotify-subscribe
  • gotify-server-push
  • gotify-server-subscribe
  • gotify
