node-red-contrib-googlehome 1.0.0
A Smart Home Action for Google Home
npm install node-red-contrib-googlehome
A set of Node-RED nodes to allow Node-RED to act as a endpoint for Google Home Smart Home Action
In the Node-RED user directory (e.g. ~/.node-red) run the following command:
or use the palette manager to install the node directly from with in Node-RED
You will need an account here. Once you have an account you can define a number of devices. You can then configure a node to represent that device in a Node-RED flow.
The full documentation can be found here
Minimum NodeJS version is now 20 (uses fetch to replace request)
Version: 1.0.0
Updated 7 months, 2 weeks ago
Rating: 3.6 7
70 in the last week
  • google-home-conf
  • google-home
  • google-home-response
  • Google Home
