node-red-contrib-google-smarthome 0.6.1
Lets you control Node-Red via Gemini, Google Assistant, or the Google Home App
npm install node-red-contrib-google-smarthome
Table of Contents
Introduction
A collection of Node-RED nodes to control your smart home devices via Gemini, Google Assistant, or the Google Home app.
This is done by implementing a smart home provider that runs on your own host. So you don't have to rely on any third party services (other than Google) that can go offline, charge you, or leak your data.
What this module does NOT do:
  • It is not a cloud-hosted solution that you just install and it works. You host a publicly accessible service on your own hardware. It can be difficult to set up. And you do this at your own risk.
  • It does not talk to your physical devices. It only provides virtual devices in Node-RED. It's up to you to pass commands from the virtual to the physical devices.
  • It is not an interface to Google devices (like Nest Thermostats, Nest Cams, etc.).
  • It is for controlling devices only. It does not let you implement your own conversations with Gemini or Google Assistant.
Prerequisites and Setup Instructions
Follow our setup instructions.
Nodes in this package
General Information
  • If online is set to false for a node, Google SmartHome will not be able to control the node. It will also show up as offline in the Google Home app.
  • Nodes will do their best to convert incoming payload data to the required type. For example, you can send a string of ON and it will be converted to true.
  • Topics must be either as listed below or prepended with one or more /. E.g. my/topic/on. The nodes will only look for the part after the last /, if any.
Google device node
This is a generic node that supports the following Google devices:
  • Air conditioning unit
  • Air cooler
  • Air freshener
  • Air purifier
  • Audio-Video receiver
  • Awning
  • Bathtub
  • Bed
  • Blanket
  • Blender
  • Blinds
  • Boiler
  • Camera
  • Carbon monoxide detector
  • Charger
  • Closet
  • Coffee Maker
  • Cooktop
  • Curtain
  • Dehumidifier
  • Dehydrator
  • Dishwasher
  • Door
  • Doorbell
  • Drawer
  • Dryer
  • Fan
  • Faucet
  • Fireplace
  • Freezer
  • Fryer
  • Game console
  • Garage
  • Gate
  • Grill
  • Heater
  • Hood
  • Humidifier
  • Kettle
  • Light
  • Lock
  • Microwave
  • Mop
  • Mower
  • Multicooker
  • Network
  • Outlet
  • Oven
  • Pergola
  • Pet feeder
  • Pressure cooker
  • Pump
  • Radiator
  • Refrigerator
  • Remote control
  • Router
  • Scene
  • Security system
  • Sensor
  • Settop
  • Shower
  • Shutter
  • Smoke detector
  • Soundbar
  • Sousvide
  • Speaker
  • Sprinkler
  • Stand mixer
  • Streaming box
  • Streaming soundbar
  • Streaming stick
  • Switch
  • Thermostat
  • Television
  • Vacuum
  • Valve
  • Washer
  • Water heater
  • Water purifier
  • Water softener
  • Window
  • Yogurt maker
and the following Google traits:
  • App selector
  • Arm/Disarm
  • Brightness
  • Camera stream
  • Channel
  • Color setting
  • Color temperature
  • Cook
  • Dispense
  • Dock
  • Energy storage
  • Fan speed
  • Fill
  • Humidity setting
  • Input selector
  • Light effects
  • Locator
  • Lock/Unlock
  • Media state
  • Modes
  • Network control
  • Object detection
  • On/Off
  • Open/Close
  • Reboot
  • Rotation
  • Run cycle
  • Scene
  • Sensor state
  • Software update
  • Start stop
  • Status report
  • Temperature control
  • Temperature Setting
  • Timer
  • Toggles
  • Transport control
  • Volume
Example flow: See the flow used for the automated tests here
Management
topic can be restart_server, report_state or request_sync.
payload is not used for anything.
restart_server restarts the built-in web server.
report_state will force an update of all states to Google. Mostly useful for debugging.
request_sync will ask Google for a sync to learn about new or changed devices. This is usually done automatically.
The config node
Name: A name for your config node.
Enable Node Debug: If enabled, debug messages will be written to Node-RED's log output.
Default Language: The language of your project.
Local Authentication
Username and Password: Username and password used during account linking in the Google Home app.
Actions on Google Project Settings
Client ID: The client ID you entered in the Actions on Google project.
Client Secret: The client secret you entered in the Actions on Google project.
Google HomeGraph Settings
Jwt Key: Path to the JSON file that you downloaded during setup. Can be an absolute path or a path relative to Node-REDs user dir (where your settings.js, flows.json etc. are stored).
Web Server Settings
Port: TCP port of your choice for incoming connections from Google. Must match what you specified in the Actions on Google project. If empty, it will use the same port as Node-RED.
URL subpath: URL subpath to add to the URL. If set, the URL will change from https://example.com:3001/check to https://example.com:3001/<subpath>/check (resp. /<subpath>/smarthome, /<subpath>/oauth, /<subpath>/token).
Use http Node-RED root path: If enabled, use the same http root path prefix configured for Node-RED, otherwise use /.
Use external SSL offload: If enabled, the smarthome service will use HTTP instead of HTTPS. Check if you want to do SSL termination on a reverse proxy.
Public Key: Full path to the SSL certificate file, e.g. fullchain.pem from Let's Encrypt.
Private Key: Full path to private SSL key file, e.g. privkey.pem from Let's Encrypt.
Note: Certificates are automatically reloaded after renewal. You don't need to restart Node-RED.
Local Fulfillment
Scan Type: The service discovery method to use. Must match what is set in the Actions on Google project.
Discovery Port: A port number to use for UDP or mDNS service discovery.
HTTP Port: A port number to use for the connection from your smart speaker to Node-RED. If empty, it will use the same port as Node-RED. If you are using Node-RED's built-in HTTPS encryption or have a httpAdminRoot set, you need to set a port. Don't create a forwarding rule for this port!
Sending spoken notifications
Some devices support sending spoken notifications to your smart speaker. For example, you can play a notification on your speaker when someone rings at the front door or when the washing machine completes a cycle. Unfortunately, you cannot send custom notifications, you can only trigger predefined notifications.
See https://developers.google.com/assistant/smarthome/develop/notifications.
  1. Using the "Google Device" node, create a device with one of the supported traits in Node-RED and deploy it. Currently, only the Object Detection, Run Cycle, and Sensor State traits support notifications.
  2. In the Google Home app, open your new device and enable Spoken Notifications.
  3. To trigger the notification, send a message with a specific payload to the device node. You can find examples for all supported notifications in the examples folder (examples/Spoken%20Notifications). Payloads are documented here.
Inviting other users
You can invite other people into your smart home in the app by following these steps.
Troubleshooting
  • Some devices can be controlled by voice, but not by the Google Home app. For example windows and sensors. These devices will only show a general page with their room assignments in the app, but they don't show their current state or any buttons to control them. There is nothing we can do about this. This has to be implemented by Google.
  • Assign your devices to a room. Unassigned devices may experience delayed state updates in the app.
  • Say "Hey Google, force default" to reset Google back to the default fulfilment mode (local with fallback to cloud fulfillment), in case Google was actively or inadvertently switched to local-only fulfilment.
  • Some errors and possible solutions are listed at Possible errors.
  • Check Node-Red's debug panel for error messages.
  • Unlink and relink your account in the Google Home app. Check Node-RED's debug panel for errors while doing so.
  • If you are having trouble linking your account, try turning off Wi-Fi on your phone to use only the cellular network.
  • Restart your flows (using the Restart Flows option in the dropdown menu of the deploy button) while the debug panel is open to see any error messages during initialization.
  • Check the logs at Google Cloud Logs. Make sure you selected the correct project.
  • Check if your service is reachable from the outside. Use reqbin.com or a similar tool to send a GET request to https://example.com:3001/check (with your hostname and port). It should respond with status 200 (OK) and the message "SUCCESS - Cloud fulfillment HTTP server is reachable" as one of the first lines. Use https://www.ssllabs.com/ssltest/ to check your SSL certificate.
  • Check Node-RED's log output. Where you find it depends on how you installed Node-Red. Usually something like journalctl -u nodered, docker logs <container> or a file in /var/log.
  • Toggle "Enable Node debug" in the configuration node, connect a debug node to the output of the management node and look for debug messages. In the Node-Red UI select 'Restart Flows' on the 'Deploy' button to see messages during initialization.
  • Check that you have only one single management node and one single config node.
  • Go through the setup instructions again and compare your settings with what you see on the screenshots.
For problems related to local fulfillment, see Troubleshooting local fulfillment.
Contact us
Developer resources
Credits
Parts of this README and much of the code come from Google. In particular, Actions on Google: Smart Home sample using Node.js was of great value.
Copyright and license
Copyright 2018 - 2026 Michael Jacobsen and others under the GNU General Public License version 3.
Version: 0.6.1
Updated 1 month, 1 week ago
License: GPL-3.0
Rating: 4.3 21
107 in the last week
  • googlesmarthome-client
  • google-mgmt
  • google-device
  • google
  • smarthome
  • assistant
  • iot
