node-red-contrib-google-sheets-advance 1.0.0
Nodered node for reading, writing, appending, clearing, adding, and removing sheets
npm install node-red-contrib-google-sheets-advance
Google Sheets Logo node-red-contrib-google-sheets-advance
License Donate
In order to download xls one has to enable Google Drive API.
A versatile Node-RED node for interacting with Google Sheets, supporting features like reading, writing, appending, clearing, adding, and removing sheets.
Table of Contents
Install via nodered pallete or run the following command in the root directory of your Node-RED install
Configure the node with your Google service account credentials and the desired method (e.g., get, update, append, clear, add sheet).
For detailed instructions on setting up authentication, sheet IDs, and cell references, refer to the Auth, Sheets, and Cells sections below.
Google Sheets Node
This node allows you to interact with Google Sheets.
  • auth: The authentication node containing the Google API credentials.
  • spreadsheetId: The ID of the Google Spreadsheet.
  • range: The range of cells to read or write.
  • operation: The operation to perform (get or append).
Auth
Follow these steps to set up authentication:
  1. Create a new service account from Google Cloud Console.
  2. Download the JSON credentials file for the service account.
  3. Give the service account access to the Google Sheets API.
  4. Share your sheet with the email address of the service account (e.g., [email protected]).
Auth
⚠️ Important Note: If service account key creation is disabled in your organization, follow the steps below to enable it:
Enabling Service Account Key Creation
If you encounter a message stating that "Service account key creation is disabled", follow these steps:
  1. Go to Google Cloud Console.
  2. Click to select your project/organization.
  3. Click the three-dot menu (⋮) next to the organization name and select IAM/PERMISSIONS.
  4. Edit your user and add the following roles:
    • Organization Policy Administrator
    • Organization Administrator
📝 Note: These roles must be added at the organization level to be effective. If you're at the project level, you might not see the required policies.
  1. After assigning the roles, go to IAM & Admin > Organization Policies.
  2. Search for the policy "Disable service account key creation".
  3. Click on Edit Policy and change the rule to allow key creation.
More details: Reddit thread
Sheets
To find the sheet ID:
  • Open your Google Sheet.
  • Copy the ID from the URL (e.g., https://docs.google.com/spreadsheets/d/your-sheet-id/edit).
Cells
Referencing cells in Google Sheets:
  • The format is Sheet1!A1:C3, where Sheet1 is the sheet name, ! indicates the cell range, and A1:C3 specifies the cells.
  • A range of cells can be a row (e.g., A1:A5), a column (e.g., A1:E1), or a block (e.g., A1:C3).
Add Remove Sheet
Adding and Remove a Sheet
To add/remove a sheet from the workbook, simply pass the desired name for the sheet to be added/removed from the workbook in msg.cells.
Download Sheet
In order to download pdf/xls permissions to Google Drive API is required.
Simply add sheet ID and select pdf or xlsx to be downloaded. Write the buffer data to a file with deired location and file name with correct extension.
C:\Users\Admin.node-red\export.pdf
Credits
This tool is built upon code references and inspiration from the node-red-contrib-google-sheets repository. We acknowledge and appreciate the contributions of the original authors and maintainers of that repository.
Future Plans
Our future plans for this tool include:
  • Enhancing user interface for better usability.
  • Adding support for additional Google Sheets API functionalities.
Feature Requests
If you have any feature requests or suggestions, please open an issue on GitHub. We welcome your feedback and ideas!
Support
For support or questions, you can contact us directly.
Version: 1.0.0
Updated 1 year, 8 months ago
Rating: 5.0 5
137 in the last week
  • GSheetAdvance
  • gauthAdv
  • gsuite
  • google sheets
  • gSheetAdvance
  • googleapis
