node-red-contrib-gitlabapi 0.0.6
Node-RED node for gitlabapi
npm install node-red-contrib-gitlabapi
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-gitlabapi, or run the following command in your Node-RED user directory, typically ~/.node-red
Wrapper gitlab API
Credentials Node for Access Token & URL
Sample parameters
// msg.method = 'get';
// msg.api = 'issues';
// msg.path = '';
msg.params = {}
// msg.params.assignee_id=1
// msg.params.author_id=5
// msg.params.labels='test'
// msg.params.state='opened'
msg.params.state='closed'
Sample Flow
You can make this json string into a flow by using the node-red flow import function.
alt
Version: 0.0.6
Updated 3 years, 4 months ago
Rating: 5.0 2
53 in the last week
  • gitlabapi
  • gitlabapiApiKey
  • node-red-contrib-contribgen
  • gitlabapi
  • gitlab API
  • nodejs
