node-red-contrib-gitlab 0.0.7
Node-RED node using GitLab APIs
npm install node-red-contrib-gitlab
Node-RED node using GitLab APIs. This is a wrapper around node-gitlab. Check it out for more info.
How to Install
To install Node, please refer to the following site.
https://nodered.org/docs/getting-started/adding-nodes
(Japanese) https://nodered.jp/docs/getting-started/adding-nodes
Available functions(APIs)
The following functions(APIs) can be used:
Project Issues
  • List issues : Get a list of project issues.
  • Create issue : Creates a new project issue.
  • Update issue : Updates an existing project issue. This function is also used to mark an issue as closed.
  • List notes of an issue : Gets a list of all notes for a single issue.
  • Create note of an issue : Creates a new note to a single project issue.
  • Update note of an issue : Modify existing note of an issue.
Repository Files
  • Get File : Get file from repository. Allows you to receive information about file in repository like name, size, content. Note that file content is Base64 encoded.
  • Create File : Create new file in repository
  • Update File : Update existing file in repository
  • Remove File : Delete existing file in repository
Copyright and license
Copyright (c) 2017 Kota Suizu
Released under the MIT license
http://opensource.org/licenses/mit-license.php
Version: 0.0.7
Updated 8 years, 6 months ago
19 in the last week
  • gitlab-config
  • GitLab-List-Issues
  • GitLab-Create-Issue
  • GitLab-Update-Issue
  • GitLab-List-Notes
  • GitLab-Create-Note
  • GitLab-Update-Note
  • GitLab-Get-RepositoryFile
  • GitLab-Create-RepositoryFile
  • GitLab-Update-RepositoryFile
  • GitLab-Remove-RepositoryFile
  • nodered
  • gitlab
  • git
  • bluemix
