node-red-contrib-gitea 0.1.0
Node-RED Gitea nodes
npm install node-red-contrib-gitea
node-red-gitea
Gitea nodes for Node-RED.
You need a gitea access token to use these nodes.
  • Get all isses of a repository
  • Get all labels of an issue
  • Add comment to an issue
More nodes will be added over time. I don't expect a high demand for this package anyways, but if missing nodes get requested, I should be able to add them rather quickly.
Pagination
For nodes like "get issues", the pagination handling can be taken care of. In this case, the node qould query all pages one by one and return an array containing all items.
This feature is optional and pagination can be manually handled by providing page und limit parameters.
You can either install this package from within Node-RED using the command palette and search for "node-red-gitea", or you run the following command in your Node-RED user directory (typically ~/.node red on Linux, %APPDATA%\node-red on Windows):
npm install node-red-gitea
Version: 0.1.0
Updated 2 years, 4 months ago
  • gitea integration
  • gitea-get-issues
  • gitea-get-issue-labels
  • gitea-send-issue-comment
  • gitea
