node-red-contrib-gira-endpoint 1.1.9
Node-RED node for Gira url Endpoint
npm install node-red-contrib-gira-endpoint
platform npm downloads MIT License
Integrate your Gira Homeserver devices with Node-RED
Quick Start
Install with the built in Node-RED Palette manager or using npm:
Example
example output
Help
This node requires configuration, Hostname or IP Adress of the Gira Homeserver and Username, Password of User to connect. HS-Experte
Anmeldung Adresse
input's type. The Input Accept Value of true|false|toggle|String|Number if one url Endpoint in configuration. More Value are seperat as ",".
See the LICENSE file for license rights and limitations (MIT).
Version: 1.1.9
Updated 5 years ago
Rating: 5.0 2
3 in the last week
  • gira-home
  • gira-in
  • gira-out
  • gira
  • websockets
  • X1
  • homeserver
  • knx
