node-red-contrib-ghostforge-vaultkey 1.3.0
GhostForge VaultKey - JIT authentication and secret burning for Node-RED. Secure GCP Secret Manager integration with zero-persistence token handling.
npm install node-red-contrib-ghostforge-vaultkey
GhostForge™ VaultKey — JIT authentication and secret burning for Node-RED.
Part of the GhostForge™ Node-RED toolkit.
What it does
Two nodes that work as a pair to handle secrets securely in Node-RED flows:
gf-master-key — Fetches a fresh GCP access token JIT (just-in-time) from the GCP Metadata Server on every message. Optionally fetches additional secrets from GCP Secret Manager. Secrets are placed in msg.secret and never stored.
gf-burner — Deletes msg.secret from the message immediately after use. Place this node right after any HTTP request node to ensure secrets never travel further in the flow.
Design philosophy
  • Zero persistence — Tokens are fetched fresh on every message, never cached
  • Zero hardcoding — All credentials live in GCP Secret Manager
  • Zero exposure — The Burner node destroys secrets the moment they are no longer needed
  • Minimal footprint — Two small nodes, one job each
Via Node-RED Palette Manager: search for ghostforge-vaultkey
Or via npm:
Requirements
  • Node-RED >= 3.0.0
  • Running on a GCP VM with a service account that has Secret Manager access
  • GCP Secret Manager API enabled in your project
[inject] → [gf-master-key] → [your function node] → [gf-burner] → [http request]
Configure gf-master-key with your GCP Project ID and the list of secrets to fetch. Each secret appears as msg.secret["secret-name"] downstream.
Place gf-burner immediately after your last node that needs the secrets.
Part of the GhostForge™ toolkit
  • ghostforge-vaultkey — JIT auth & secret burning (this package)
  • ghostforge-flowgate — API call queue & rate limiting
  • ghostforge-arrows — Visual flow routing nodes
GhostForge™ is a trademark of Zerr Remoteservice
Version: 1.3.0
Updated 8 months, 2 weeks ago
82 in the last week
  • gf-master-key
  • gf-burner
  • gcp
  • security
  • secrets
  • authentication
  • ghostforge
