node-red-contrib-ghostforge-arrows 1.4.0
GhostForge Arrows - Visual flow routing nodes for Node-RED. Directional arrow nodes for clean, readable flow design.
npm install node-red-contrib-ghostforge-arrows
GhostForge™ Arrows — Visual flow routing nodes for Node-RED.
Part of the GhostForge™ Node-RED toolkit.
What it does
Four directional arrow nodes that pass messages unchanged and serve as visual guides in complex Node-RED flows:
  • gf-arrow-up ↑
  • gf-arrow-down ↓
  • gf-arrow-left ←
  • gf-arrow-right →
Design philosophy
Node-RED flows can become visually complex with many crossing wires. Arrow nodes give you a way to indicate flow direction explicitly - making flows readable at a glance without relying on wire routing alone.
All arrow nodes are minimal: black background, white icon, no label. They blend naturally into the GhostForge™ node family.
Via Node-RED Palette Manager: search for ghostforge-arrows
Or via npm:
Drop an arrow node anywhere in your flow to visually indicate direction. Wire it in-line like any other node - it simply passes msg through unchanged.
[node A] → [gf-arrow-down] → [node B]
Part of the GhostForge™ toolkit
  • ghostforge-vaultkey — JIT auth & secret burning
  • ghostforge-flowgate — API call queue & rate limiting
  • ghostforge-arrows — Visual flow routing nodes (this package)
GhostForge™ is a trademark of Zerr Remoteservice
Version: 1.4.0
Updated 8 months, 2 weeks ago
83 in the last week
  • visual
  • routing
  • design
  • ghostforge
