node-red-contrib-ghost-client 1.1.0
Node-RED nodes to interact with Ghost API client (@tryghost/admin-api)
npm install node-red-contrib-ghost-client
Node-RED Ghost Admin API Client Nodes
Buy me a beer
A Node-RED node package providing nodes to interact with the Ghost Admin API using the official @tryghost/admin-api client.
  • Browse, read, create (post), edit, and delete Ghost posts
  • Typed input fields for all node properties (supporting string, JSON, msg, flow, global)
  • Two outputs for each node: success and error
  • Error handling and output for all API calls
  • Example flows included
From your Node-RED user directory (~/.node-red):
Add any of the Ghost nodes to your flow:
  • ghost-config: Configure the Ghost Admin API client
  • ghost-browse: Browse resources (e.g., posts, pages)
  • ghost-read: Read a single resource by ID
  • ghost-create: Create a new post
  • ghost-edit: Edit an existing post
  • ghost-delete: Delete a post
Node Properties
Each node provides typed input fields for all required properties. See the node's help in the Node-RED editor for details and links to the Ghost Admin API documentation.
Compatibility
  • Requires Node.js 20+
  • Compatible with Node-RED 3.x+
  • Requires a Ghost site with Admin API enabled
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at LICENSE.
Version: 1.1.0
Updated 1 year, 6 months ago
  • ghost-config
  • ghost-browse
  • ghost-create
  • ghost-delete
  • ghost-edit
  • ghost-read
  • ghost
  • ghost-client
  • ghost-api
  • ghost-admin-api
  • cms
