node-red-contrib-getnet-api 2.0.3
Getnet API wrapper for Node-Red
npm install node-red-contrib-getnet-api
logo-getnet-small
This node enables you to work with the Getnet Digital Platform API, giving you the ability to set parameters through the Node-RED-UI and trigger the flow from within your existing flow.
It is based on Getnet Digital Platform API.
Getnet
1. Get the API-operations list
Operations
2. Understanding the API
Hovering on an operations title or a key, you see the respective comments within the mouseover. This allows you to understand what a parameter is meant for. Required parameters are marked with an asterisk.
parameter description
For JSON-parameters you can further show the structure by clicking on show keys. Again, the comments can be found within the mouseover.
json description
3. Parameter configuration
Each parameter has an input-field corresponding to its type. You can further define that a parameter shall be read from the incoming message object or define a jsonata expression.
JSON parameters may define a sample structure. You can set this as the value by clicking the corresponding button - either with only the required keys (set required) or with all keys (set default).
4. Authentification
If the API requires an authentification token you can log in using the standard http-request node of Node-RED. The JWT token you get as a response must then be put into msg.openApiToken to be automatically placed in the request-header as bearer authentification. In case you would like to use a different authentification than bearer, you can use msg.headers as you can do with the default http request node of Node-RED.
Both message object will be deleted afterwards if you do not set the option "Keep authentification".
5. Error handling
You can choose how to handle a returning server error. The last server response object will be placed in msg.response instead of msg.error. This ensures that all 3 ways react the same.
  • Standard: The flow moves on normally. You have to handle an server error in your flow.
  • Separate output: Your flow will take a different way.
  • Throw an exception: Throws an node.error which can be catched by the standard 'catch' node (usefull for many nodes with the same error handling).
Sample
flow.json
[{"id":"39673f6d2cb0b3b2","type":"group","z":"348240cef6de04ff","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["e0f693cd0926f0b8","3a488550f6015369","6de90ecc2bf97768"],"x":174,"y":179,"w":672,"h":82},{"id":"e0f693cd0926f0b8","type":"getnet","z":"348240cef6de04ff","g":"39673f6d2cb0b3b2","name":"","api":"Autenticação","server":"","keepAuth":false,"alternServer":false,"operation":"post/auth/oauth/v2/token","operationData":{"summary":"Geração do token de acesso","description":"Endpoint responsável pela geração do token de acesso utilizado nas demais requisições, para isso utilizamos [HTTP Basic Authentication](https://www.w3.org/Protocols/HTTP/1.0/draft-ietf-http-spec.html#BasicAA)","tags":["Autenticação"],"consumes":["application/x-www-form-urlencoded"],"produces":["application/json"],"parameters":[{"in":"formData","required":true,"type":"string","name":"grant_type","description":"Usar O valor fixo \"client_credentials\"","default":"client_credentials"},{"in":"formData","required":true,"type":"string","name":"scope","description":"Usar o valor fixo \"oob\"","default":"oob"},{"in":"header","name":"Authorization","required":true,"type":"string","description":"Authorization: Basic *AuthString* </br> Onde *AuthString* é a concatenação do seu Client ID, seguido de “:” (dois pontos) mais seu Client Secret, convertidos para base64. <br> Como exemplo: Para o Client ID igual a client-01 e Client Secret igual a secret-key-02, teremos o texto client-01:secret-key-02 após a concatenação, convertendo para base64 teremos o resultado Y2xpZW50LTAxOnNlY3JldC1rZXktMDI=.</br> Neste caso o  Authorization no header da requisição será: </br> Authorization: Basic Y2xpZW50LTAxOnNlY3JldC1rZXktMDI=\n"},{"in":"header","name":"Content-type","required":true,"type":"string","enum":["application/x-www-form-urlencoded"],"default":"application/x-www-form-urlencoded","description":"Tipo do conteúdo padrão application/x-www-form-urlencoded.\n"}],"responses":{"200":{"description":"Retorna o token de acesso.","schema":{"type":"object","properties":{"access_token":{"type":"string","description":"Token de acesso a API para envio em todas as requisições","example":"ca22a2ge-1914-4b0c-a0fb-d3ce0fde7346","format":"uuidv4","minLength":36,"maxLength":36},"token_type":{"type":"string","description":"Tipo do token, deve ser enviado no header junto do token (https://tools.ietf.org/html/rfc6750)","example":"Bearer"},"expires_in":{"type":"number","description":"Tempo de expiração do token em segundos","example":3600},"scope":{"type":"string","description":"Escopo do token","example":"oob"}}}},"400":{"description":"Requisição inválida.","schema":{"type":"object","properties":{"error":{"type":"string","description":"Mensagem de erro."},"error_description":{"type":"string","description":"Descrição do erro."}},"$$ref":"#/definitions/error_authentication"}},"401":{"description":"Não autorizado.","schema":{"type":"object","properties":{"error":{"type":"string","description":"Mensagem de erro."},"error_description":{"type":"string","description":"Descrição do erro."}},"$$ref":"#/definitions/error_authentication"}}},"x-code-samples":[{"lang":"cURL","source":"curl -X POST \\\nhttps://api-homologacao.getnet.com.br/auth/oauth/v2/token \\\n-H 'authorization: Basic Y2xpZW50LTAxOnNlY3JldC1rZXktMDI=' \\\n-H 'content-type: application/x-www-form-urlencoded' \\\n-d 'scope=oob&grant_type=client_credentials'\n"}],"operationId":"post/auth/oauth/v2/token","withoutOriginalOpId":true,"pathName":"/auth/oauth/v2/token","method":"post","path":"/auth/oauth/v2/token"},"errorHandling":"Standard","internalErrors":{"readUrl":false},"parameters":[{"id":"grant_typeformData","name":"grant_type","in":"formData","required":true,"value":"client_credentials","isActive":true,"type":"str","allowedTypes":["str","json","jsonata","msg","flow","global"],"description":"Usar O valor fixo \"client_credentials\"","schema":null,"keys":null,"showDescription":false},{"id":"scopeformData","name":"scope","in":"formData","required":true,"value":"*","isActive":true,"type":"str","allowedTypes":["str","json","jsonata","msg","flow","global"],"description":"Usar o valor fixo \"oob\"","schema":null,"keys":null,"showDescription":false},{"id":"Authorizationheader","name":"Authorization","in":"header","required":true,"value":"Basic dW5kZWZpbmVkOnVuZGVmaW5lZA==","isActive":true,"type":"str","allowedTypes":["str","json","jsonata","msg","flow","global"],"description":"Authorization: Basic *AuthString* </br> Onde *AuthString* é a concatenação do seu Client ID, seguido de “:” (dois pontos) mais seu Client Secret, convertidos para base64. <br> Como exemplo: Para o Client ID igual a client-01 e Client Secret igual a secret-key-02, teremos o texto client-01:secret-key-02 após a concatenação, convertendo para base64 teremos o resultado Y2xpZW50LTAxOnNlY3JldC1rZXktMDI=.</br> Neste caso o  Authorization no header da requisição será: </br> Authorization: Basic Y2xpZW50LTAxOnNlY3JldC1rZXktMDI=\n","schema":null,"keys":null,"showDescription":false},{"id":"Content-typeheader","name":"Content-type","in":"header","required":true,"value":"application/x-www-form-urlencoded","isActive":true,"type":"str","allowedTypes":["str","json","jsonata","msg","flow","global"],"description":"Tipo do conteúdo padrão application/x-www-form-urlencoded.\n","schema":null,"keys":null,"showDescription":false}],"requestContentType":"application/json","responseContentType":"","showDescription":false,"devMode":false,"showBanner":true,"outputs":1,"x":490,"y":220,"wires":[["6de90ecc2bf97768"]]},{"id":"3a488550f6015369","type":"inject","z":"348240cef6de04ff","g":"39673f6d2cb0b3b2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":220,"wires":[["e0f693cd0926f0b8"]]},{"id":"6de90ecc2bf97768","type":"debug","z":"348240cef6de04ff","g":"39673f6d2cb0b3b2","name":"debug 1","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":730,"y":220,"wires":[]}]
This repository and the code inside it is licensed under the MIT License. Read LICENSE for more information.
Developers
If you want to modify something inside the getnet.html file, I recommend to use SIR.
With help of SIR you can handle the getnet.svelte file in which the code is much cleaner and easier to handle.
Version: 2.0.3
License: MIT License
2 in the last week
  • getnet
  • getnet
  • rest-api
