node-red-contrib-get-history-timezone 1.1.1
Node-RED node for getting Home Assistant history with timezone conversion support
npm install node-red-contrib-get-history-timezone
A Node-RED node for retrieving Home Assistant historical data with timezone conversion support.
  • Retrieve historical data from Home Assistant
  • Convert UTC timestamps to any timezone
  • Support for relative time periods (e.g., "2 hours", "1 day")
  • Entity filtering with regex support
  • Configurable output format
Install from npm:
Or install directly in Node-RED:
  1. Go to the Node-RED menu (hamburger icon)
  2. Select "Manage palette"
  3. Click "Install" tab
  4. Search for "node-red-contrib-get-history-timezone"
  5. Click "Install"
  1. Server: Select your Home Assistant server configuration
  2. Entity ID: Specify the entity ID(s) to retrieve history for
    • Use specific ID: sensor.temperature
    • Use regex pattern: sensor\..*temperature.*
  3. Time Range: Choose between:
    • Relative time: "2 hours", "1 day", "30 minutes"
    • Absolute dates: Set specific start and end dates
  4. Timezone Conversion:
    • Enable to convert UTC timestamps to local timezone
    • Select target timezone or use system timezone
  5. Output Options:
    • Flatten results: Returns flat array vs nested arrays
    • Output location: Where to store results in the message
Input Message
You can override configuration via the input message:
msg = {
    payload: {
        entityId: "sensor.temperature",
        relativeTime: "2 hours",
        convertTimezone: true,
        timezone: "Europe/Warsaw",
        flatten: true
Output
The node outputs historical data with optionally converted timestamps:
        "entity_id": "sensor.temperature",
        "state": "23.5",
        "attributes": {...},
        "last_changed": "2025-10-06T14:57:55.374689+02:00",  // Converted to local timezone
        "last_updated": "2025-10-06T14:57:55.374689+02:00"   // Converted to local timezone
Timezone Support
The node supports timezone conversion using standard IANA timezone identifiers:
  • system - Use Node-RED server's system timezone
  • Europe/Warsaw - Polish timezone
  • Europe/London - UK timezone
  • America/New_York - Eastern US timezone
  • UTC - Coordinated Universal Time
  • Any other valid IANA timezone identifier
Requirements
  • Node-RED 3.0.0+
  • Home Assistant with REST API access
  • Valid Home Assistant access token
MIT
Contributing
Issues and pull requests are welcome on GitHub.
Changelog
1.0.0
  • Initial release with timezone conversion support
  • Configurable output options
Version: 1.1.1
Updated 1 year, 2 months ago
  • get-history-timezone
  • ha-config-server
  • home-assistant
  • history
  • timezone
  • hass
  • iot
