node-red-contrib-geniushub 0.1.0
Node RED nodes for Genius Hub
npm install node-red-contrib-geniushub
GitHub license
A collection of Node-RED nodes to control the Genius Hub heating system.
Install directly from your Node-RED's setting pallete.
You will need a token to use in the configuration of the nodes. You can create one here https://my.geniushub.co.uk/tokens by logging in with you Genius Hub credentials and clicking the + button. Note that you can set the Expiration Date to date up to a year from now. You will need to Renew the token when it expires by clicking the Renew button next to it.
Both nodes take a command through the input topic and when they output a message they set the output topic to the topic passed in. The commands are case insensitive.
whole house
This node represents the Genius Hub Whole House. It supports the following commands:
zone
This node represents a single Genius Hub zone. It supports the following commands:
  • getStatus - outputs the full state of the zone, see https://my.geniushub.co.uk/docs#operation/getZone for the schema of the output payload
  • getTemperature - outputs the temperature in Celcius as a real number.
  • getMode - outputs the current mode as one of the following strings off, timer, footprint, and override.
  • getSetpoint - outputs the temperature that the zone has been set to in Celcius as a real number.
  • getOverride - outputs the current override, see https://my.geniushub.co.uk/docs#operation/getZoneOverrideSettings for the schema of the output payload.
  • getOccupied - outputs true if the zone is occupied and false if it is not.
  • getTimerSchedule - outputs the weekly schedule of the timer, see https://my.geniushub.co.uk/docs#operation/getZoneTimerSchedule for the schema of the output payload. (Note that this currently returns an error 500).
  • getFootprintSchedule - outputs the weekly schedule created by the footprint feature, see https://my.geniushub.co.uk/docs#operation/getZoneFootprintSchedule for the schema of the output payload.
  • off - set the zone to the off mode.
  • timer - set the zone to the timer mode.
  • footprint - set the zone to the footprint mode,
  • override - set an override for the zone. The payload can contain a setpoint in Celcius and a duration in seconds, If either are omitted the current override will be updated. If there is no payload the default override will be set.
Known Issues
  • The whole house off command only turns of zones with the type radiator. Please let me know the zone type of any other zones that should be turned off by this.
  • The whole house restore command will only undo what was done by a preceding off command. It will not be able to undo an off that has been done through the Genius Hub app or web site.
  • According to the documentation at https://my.geniushub.co.uk/docs# whole house getSummary should return the type as well as the id and name of a zone but unfortunately it doesn't.
  • The whole house getTimerSchedule command currently return an HTTP error 500 as that is what it gets from the Genius Hub cloud. Can this be confirmed as in issue?
Example Flows
Zone Flow
Version: 0.1.0
Updated 6 years, 11 months ago
1 in the last week
  • geniushub-service
  • geniushub-whole-house
  • geniushub-zone
  • geniushub
  • genius-hub
  • home-automation
  • smarthome
  • heating
  • energy
