node-red-contrib-generate-password 0.1.0
NodeRed generate-password
Node RED
Node-RED is a tool for wiring together hardware devices, APIs and online services in new and interesting ways.
:question: Get Help
For bug reports and feature requests, open issues. :bug:
:sparkling_heart: Support my projects
I open-source almost everything I can, and I try to reply to everyone needing help using these projects. Obviously, this takes time. You can integrate and use these projects in your applications for free! You can even change the source code and redistribute (even resell it).
However, if you get some profit from this or just want to encourage me to continue creating stuff, there are few ways you can do it:
- Starring and sharing the projects you like :rocket:
PayPal— You can make one-time donations via PayPal. I'll probably buy a
coffeetea. :tea:Ko-fi— I'll buy a
teacoffee. :coffee: :wink:
Bitcoin—You can send me bitcoins at this address (or scanning the code): 3GqiebqcZeonziRUMYxU35J3jPSMJzpTAc
Thanks! :heart:
:cloud: Installation
First of all install Node-RED
$ sudo npm install -g node-red
# Then open the user data directory `~/.node-red` and install the package
$ cd ~/.node-red
$ npm install node-red-contrib-generate-password
Or search template in the manage palette menu
Then run
node-red
:yum: How to contribute
Have an idea? Found a bug? See how to contribute.
git clone https://github.com/naimo84/node-red-contrib-generate-password.git
cd /path/to/node-red-contrib-generate-password
npm install
gulp
npm install /path/to/node-red-contrib-generate-password
:memo: Documentation
Password Injector
This node is used to inject a password into the flow.
Options
length: 10,
numbers: true,
uppercase: false
Available options
Any of these can be passed into the options object for each function.
| Name | Description | Default Value |
| length | Integer, length of password. | 10 |
| numbers* | Boolean, put numbers in password. | false |
| symbols* | Boolean or String, put symbols in password. | false |
| lowercase* | Boolean, put lowercase in password | true |
| uppercase* | Boolean, use uppercase letters in password. | true |
| excludeSimilarCharacters | Boolean, exclude similar chars, like 'i' and 'l'. | false |
| exclude | String, characters to be excluded from password. | '' |
| strict | Boolean, password must include at least one character from each pool. | false |
Formated function
The formated function can be used like the standard node-red function node, but with the special feature {{newPassword}}. {{newPassword}} will be replaced with a new generated password.
:scroll: The MIT License
Coded with :heart: in :cloud:
