node-red-contrib-gemini 1.0.3
Node-RED nodes for Google Gemini AI integration including text generation, chat, vision, image generation, speech generation, and audio understanding capabilities
npm install node-red-contrib-gemini
A comprehensive Node-RED package providing nodes for Google's Gemini AI models, covering text generation, chat, vision, image generation, audio understanding, and speech synthesis.
Included Nodes
  • gemini-generate-content: Text generation, multi-turn chat, and vision analysis.
  • gemini-image-generate: Create and edit images (Imagen 3 / Gemini).
  • gemini-speech-generate: High-quality text-to-speech synthesis.
  • gemini-audio-understand: Transcription and analysis of audio files.
  • gemini-api-key: Secure API credential management.
Quick Start
  1. Install: Search for node-red-contrib-gemini in the Node-RED Palette Manager.
  2. Get Key: Obtain a an API key from Google AI Studio.
  3. Configure: Check the API Key configuration node and paste your key.
  4. Select Model: In any node, click the Fetch Models (refresh) button to load the latest available models directly from Google.
Key Features
  • Dynamic Model Fetching: Automatically access new models as they are released without package updates.
  • Multimodal Support: Seamlessly handle text, images, video, and audio.
  • Mustache Templating: Use {{msg.payload}} or {{msg.topic}} in prompts and text fields.
  • Advanced Options: Support for Google Search Grounding, Streaming responses, and JSON/Enum output.
  • Output Control: Send results to msg.payload, files, or custom properties.
Examples
Text Generation with Grounding & Structured Output
        "id": "e8a423a769b8dec0",
        "type": "gemini-generate-content",
        "z": "a6c480dcb27b87bd",
        "g": "7c41675671016995",
        "apiKey": "fe0d58f14ac27f69",
        "modelSelection": "gemini-3-flash-preview",
        "customModel": "",
        "customModelType": "str",
        "mode": "single",
        "prompt": "Does the movie {{msg.payload.movie}} have an after credits scene? Answer as briefly as possible. ",
        "promptType": "str",
        "multimodalInputsData": "[]",
        "grounding": true,
        "temperature": "1",
        "temperatureType": "num",
        "topP": "0.95",
        "topPType": "num",
        "topK": "64",
        "topKType": "num",
        "maxOutputTokens": "8192",
        "maxOutputTokensType": "num",
        "safetyHarassment": "BLOCK_MEDIUM_AND_ABOVE",
        "safetyHateSpeech": "BLOCK_MEDIUM_AND_ABOVE",
        "safetySexuallyExplicit": "BLOCK_MEDIUM_AND_ABOVE",
        "safetyDangerousContent": "BLOCK_MEDIUM_AND_ABOVE",
        "thinkingBudget": "-1",
        "thinkingBudgetType": "num",
        "thinkingLevel": "",
        "thinkingLevelType": "str",
        "includeThoughts": false,
        "systemInstruction": "",
        "systemInstructionType": "str",
        "outputProperty": "msg.payload.details",
        "passthroughProperties": false,
        "responseFormat": "json",
        "schemaPropertiesData": "[{\"name\":\"afterCredits\",\"type\":\"BOOLEAN\",\"required\":true},{\"name\":\"details\",\"type\":\"STRING\",\"required\":true},{\"name\":\"sourceURL1\",\"type\":\"STRING\",\"required\":true},{\"name\":\"sourceURL2\",\"type\":\"STRING\",\"required\":false}]",
        "enumValues": "",
        "x": 650,
        "y": 500,
                "14a2617d6e1c1a49"
                "14a2617d6e1c1a49"
        "id": "0553c65f94a35371",
        "type": "inject",
        "name": "Send movie example (structured output + grounding)",
        "props": [
                "p": "payload.movie",
                "v": "The Long Walk",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 310,
        "y": 500,
                "e8a423a769b8dec0"
        "id": "14a2617d6e1c1a49",
        "type": "debug",
        "name": "Text generate (grounding + search) debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1020,
        "y": 500,
        "id": "fe0d58f14ac27f69",
        "type": "gemini-api-key",
        "name": "node-red-free"
        "id": "90b01cfcf7ce8cba",
        "type": "global-config",
        "env": [],
        "modules": {
            "node-red-contrib-gemini": "1.0.2"
Image Generation & Editing
[{"id":"be4d6ff6a36494ee","type":"group","z":"a6c480dcb27b87bd","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["6fc837881ae39da0","c48c713b1208e241","a7f861aa9e06a8bb","a773e54e40b4e08b","f877c30efdbbeeeb","18ea36bf88be42b6","ea909ae5b69bfe15"],"x":64,"y":739,"w":1562,"h":262},{"id":"6fc837881ae39da0","type":"gemini-image-generate","z":"a6c480dcb27b87bd","g":"be4d6ff6a36494ee","name":"Generate Image","apiKey":"86f1d6e41a7140a9","modelSelection":"gemini-2.5-flash-image","customModel":"","customModelType":"str","prompt":"Generate an image of Scooby Doo having fun with his best friend, a green banana. They should be in a jurassic era volcanic setting with dinosaurs lurking","promptType":"str","numberOfImages":"1","numberOfImagesType":"num","aspectRatio":"1:1","outputFormat":"base64","saveDirectory":"","saveDirType":"str","mode":"generate","inputFile":"","inputFileType":"str","outputProperty":"msg.inputImages","systemInstruction":"","systemInstructionType":"str","responseModalities":"image","safetyHarassment":"BLOCK_MEDIUM_AND_ABOVE","safetyHateSpeech":"BLOCK_MEDIUM_AND_ABOVE","safetySexuallyExplicit":"BLOCK_MEDIUM_AND_ABOVE","safetyDangerousContent":"BLOCK_MEDIUM_AND_ABOVE","x":440,"y":800,"wires":[[["c48c713b1208e241","ea909ae5b69bfe15","a773e54e40b4e08b"],["ea909ae5b69bfe15"]]]},{"id":"c48c713b1208e241","type":"image viewer","z":"a6c480dcb27b87bd","g":"be4d6ff6a36494ee","name":"","width":"580","data":"inputImages","dataType":"msg","active":true,"x":930,"y":780,"wires":[[]]},{"id":"a7f861aa9e06a8bb","type":"inject","z":"a6c480dcb27b87bd","g":"be4d6ff6a36494ee","name":"Test image gen and edit","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":800,"wires":[["6fc837881ae39da0"]]},{"id":"a773e54e40b4e08b","type":"gemini-image-generate","z":"a6c480dcb27b87bd","g":"be4d6ff6a36494ee","name":"Modify Image","apiKey":"86f1d6e41a7140a9","modelSelection":"gemini-2.5-flash-image","customModel":"","customModelType":"str","prompt":"Add a spooky jack o' lantern on top of scooby's head","promptType":"str","numberOfImages":"1","numberOfImagesType":"num","aspectRatio":"1:1","outputFormat":"base64","saveDirectory":"","saveDirType":"str","mode":"edit","inputFile":"","inputFileType":"str","outputProperty":"payload","systemInstruction":"","systemInstructionType":"str","responseModalities":"image","safetyHarassment":"BLOCK_MEDIUM_AND_ABOVE","safetyHateSpeech":"BLOCK_MEDIUM_AND_ABOVE","safetySexuallyExplicit":"BLOCK_MEDIUM_AND_ABOVE","safetyDangerousContent":"BLOCK_MEDIUM_AND_ABOVE","x":500,"y":960,"wires":[[["f877c30efdbbeeeb","18ea36bf88be42b6"],["f877c30efdbbeeeb"]]]},{"id":"f877c30efdbbeeeb","type":"debug","z":"a6c480dcb27b87bd","g":"be4d6ff6a36494ee","name":"image 2 debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":760,"y":860,"wires":[]},{"id":"18ea36bf88be42b6","type":"image viewer","z":"a6c480dcb27b87bd","g":"be4d6ff6a36494ee","name":"","width":"580","data":"payload","dataType":"msg","active":true,"x":1530,"y":780,"wires":[[]]},{"id":"ea909ae5b69bfe15","type":"debug","z":"a6c480dcb27b87bd","g":"be4d6ff6a36494ee","name":"image 1 debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":760,"y":820,"wires":[]},{"id":"86f1d6e41a7140a9","type":"gemini-api-key","name":"node-red-paid"}]
Audio Generation & Understanding
        "id": "eba78a6484fd41a0",
        "type": "gemini-speech-generate",
        "g": "e853ab82cdb9436c",
        "model": "gemini-2.5-flash-preview-tts",
        "text": "james: Hello! I have no idea what I'm doing. blueman: This is a test of the multi-speaker generation with gemini in node-red",
        "textType": "str",
        "speakerMode": "multi",
        "voiceName": "",
        "speaker1Name": "james",
        "speaker1Voice": "Achernar",
        "speaker2Name": "blueman",
        "speaker2Voice": "Iapetus",
        "outputFormat": "buffer",
        "saveDirectory": "",
        "saveDirType": "str",
        "filename": "itsatest2",
        "filenameType": "str",
        "maxOutputTokens": "",
        "outputProperty": "msg.audioData",
        "x": 590,
        "y": 660,
                "f06072a81460fba7",
                "7e5e2bc15661e2c7"
                "f06072a81460fba7"
        "id": "ec11788db1f8ad68",
        "type": "inject",
        "name": "Geenrate audio and then understand it example",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 280,
        "y": 660,
                "eba78a6484fd41a0"
        "id": "f06072a81460fba7",
        "type": "debug",
        "name": "Speech generate debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 970,
        "y": 660,
        "id": "7e5e2bc15661e2c7",
        "type": "gemini-audio-understand",
        "model": "gemini-2.5-flash",
        "prompt": "Transcribe this for me, identifying individual speakers",
        "audioFile": "",
        "audioFileType": "str",
        "temperature": "",
        "topP": "",
        "topPType": "num",
        "topK": "",
        "topKType": "num",
        "outputFormat": "text",
        "outputProperty": "payload",
        "x": 890,
        "y": 600,
                "887cf6ec214ba54b"
                "887cf6ec214ba54b"
        "id": "887cf6ec214ba54b",
        "type": "debug",
        "name": "Audio understand debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1210,
        "y": 600,
        "id": "5033da0e83edc623",
        "env": [],
        "modules": {
Disclaimer
This package was written with Claude Code. I'm not a developer by trade and am new to Git as a whole. This is also my first node-red package. I had a use for interfacing with Gemini in my node-red setup and wanted a better way of doing it. I tried to add features that I thought may be useful to a broader audience. I'll do my best to support this and keep it functional. I hope it's able to make your flows a little bit more robust :)
Instructions were given to stay within the confines of the Gemini API documentation https://ai.google.dev/gemini-api/docs as well as the Node.js SDK written by Google https://github.com/googleapis/js-genai. It was built against SDK version 1.27.0.
MIT License. Copyright (c) 2025.
Version: 1.0.3
Updated 11 months, 1 week ago
47 in the last week
  • gemini-api-key
  • gemini
  • google-ai
  • ai
  • artificial-intelligence
  • text-generation
  • chat
  • vision
  • image-generation
  • speech-generation
  • audio-understanding
  • transcription
  • audio
  • multimodal
