node-red-contrib-gearmind 1.0.5
A Node-RED node for interacting with the GearMind API for industrial evolution
npm install node-red-contrib-gearmind
A Node-RED node for interacting with the GearMind API for industrial evolution.
Description
This Node-RED node allows you to easily integrate GearMind API capabilities into your Node-RED flows. It provides a simple interface to send requests to the GearMind API and receive responses, enabling you to leverage industrial evolution features in your automation projects.
  1. Drag the "GearMind" node from the palette to your flow.
  2. Double-click on the node to configure it.
  3. Enter your GearMind API Key in the configuration panel.
  4. Connect the node to your flow.
Input
The node expects an input message with a payload containing an array of message objects to send to the GearMind API. For example:
msg.payload = [
    {"role": "system", "content": "You are an industrial expert."},
    {"role": "user", "content": "How can I optimize my manufacturing process?"}
Output
The node will output a message with the payload containing the response content from the GearMind API as a string.
Example Flow
Here's a simple example of how to use the GearMind node:
[{"id":"f6f2187d.f17ca8","type":"inject","z":"b068e77.4ebfce8","name":"Trigger","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":100,"y":80,"wires":[["2b1c54c4.79795c"]]},{"id":"2b1c54c4.79795c","type":"function","z":"b068e77.4ebfce8","name":"Prepare Request","func":"msg.payload = [\n    {\"role\": \"system\", \"content\": \"You are an industrial expert.\"},\n    {\"role\": \"user\", \"content\": \"How can I optimize my manufacturing process?\"}\n];\nreturn msg;","outputs":1,"noerr":0,"x":280,"y":80,"wires":[["3f7caa4.ec0c706"]]},{"id":"3f7caa4.ec0c706","type":"gearmind","z":"b068e77.4ebfce8","name":"","apiKey":"","x":460,"y":80,"wires":[["e6b3d73a.d02c18"]]},{"id":"e6b3d73a.d02c18","type":"debug","z":"b068e77.4ebfce8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":650,"y":80,"wires":[]}]
The node requires a GearMind API Key for authentication. You can obtain this key from your GearMind account settings.
Security Note
Always keep your API Key confidential. Do not share it or commit it to public repositories.
Contributing
Contributions to improve node-red-contrib-gearmind are welcome. Please feel free to submit pull requests or create issues on the GitHub repository.
Support
If you encounter any issues or have questions, please file an issue on the GitHub repository.
Version: 1.0.5
Updated 2 years, 4 months ago
  • gearmind
  • gearmind
  • industrial
  • api
