node-red-contrib-gearman 1.0.6
A Node-RED node for submitting and monitoring Gearman jobs.
npm install node-red-contrib-gearman
A Node-RED node for submitting jobs to a Gearman job server and receiving results or progress updates.
Overview
This custom node lets you integrate Node-RED flows with a Gearman job server.
You can:
  • Submit jobs to Gearman workers
  • Receive results when jobs complete
  • Receive progress updates from workers
  • Monitor job status directly in Node-RED
From within your Node-RED user directory (usually ~/.node-red):
Or add it to your package.json dependencies and restart Node-RED.
If you’re using Docker:
# Build a Node-RED image with this node included
docker build -t my-nodered-gearman . docker run -it -p 1880:1880 my-nodered-gearman
Node Configuration
Connection
Field Description Default
Host Hostname or IP of the Gearman server localhost
Port Port number 4730
Job
Field Description
Job Function Name Name of the Gearman job to execute
Wait for Result If checked, the node waits for the worker to return a result; otherwise submits in background
Payload Whatever is in msg.payload will be sent as job data (JSON serialized automatically)
Usage Examples
1. Send a simple object
Inject Node Payload:
    "task": "resize",
    "width": 400,
    "height": 300
Gearman Node:
  • Job = resize_image
  • Wait for Result = checked
Worker receives:
{"task":"resize","width":400,"height":300}
2. Send only part of msg.payload
Use a Function node upstream:
// Only send the 'user' object from payload
msg.job = "generate_report";
msg.payload = msg.payload.user;
Gearman receives just:
{"id":123,"name":"Adze"}
3. Dynamic Job & Host
You can override per message:
msg.job = "resize_image";
msg.payload = { url: "https://example.com/a.jpg", width: 400 };
msg.host = "gearmand"; // optional if different host
msg.port = 4730;
Outputs
  • Output 0 – Job result (when waitForResult is true)
  • Output 1 – Progress updates from the worker
Status colors:
Status Color Meaning
Connecting / In progress 🟡 Yellow Job is being processed
Connected / Complete 🟢 Green Job completed successfully
Error / Failed 🔴 Red Job failed or connection error
Disconnected ⚫ Grey Node disconnected from Gearman
Local Development with Docker
A sample docker-compose.yml for local testing:
nodered:
    build:
      context: .
      dockerfile: Dockerfile
    container_name: nodered
    ports:
      - "1880:1880"
    environment:
      - TZ=UTC
    depends_on:
      - gearmand
    restart: unless-stopped
Run it:
docker compose up --build
Then open http://localhost:1880 and use your new Gearman node.
Testing
You can test by running a simple Gearman worker:
gearman -w -f echo -- cat
Then send a job with Node-RED using the Gearman node and observe the echo output.
MIT © 2025 adri
See LICENSE for details.
Version: 1.0.6
Updated 1 year, 1 month ago
520 in the last week
  • gearman
  • gearman
  • job
  • queue
  • worker
