node-red-contrib-gc-trigger 0.0.1
A Node Red node to trigger a garbage collection
npm install node-red-contrib-gc-trigger
A Node Red node to trigger a garbage collection in NodeJs.
Node Usage
When talking about garbage collections in NodeJS, the collections are executed in the V8. That V8 is Google's Javascript engine (written in C++), that is a.o. used to run Node.js.
In normal circumstances, the V8 engine will cleanup memory as soon as it is necessary. When the memory exceeds some threshold, the V8 engine will trigger garbage collections. This can be visualized in Node-Red using the node-red-contrib-gc node:
GC trigger monitor
However it might happen in exceptional cases that the garbage collection doesn't run often enough, since the V8 engine isn't aware about the real amount of memory being used. For example when native C++ code is being called from a NodeJS program, in some conditions NodeJs doesn't take into account all the native memory that is being used. In such conditions it might be useful to force NodeJs to trigger a garbage collection.
The garbage collection could be triggered e.g. at fixed moments in time:
GC trigger interval
[{"id":"f25703cc.accc","type":"interval","z":"96bd11be.2cff3","name":"interval","interval":"1","onstart":false,"msg":"ping","showstatus":false,"unit":"seconds","statusformat":"YYYY-MM-D HH:mm:ss","x":204,"y":624.9722290039062,"wires":[["a3ba42c3.c7e87"]]},{"id":"a3ba42c3.c7e87","type":"gc-trigger","z":"96bd11be.2cff3","display":true,"name":"","x":364.88547706604004,"y":624.3334522247314,"wires":[[]]}]
Or you could also trigger it when the memory usage exceeds some threshold (e.g. 90%):
GC trigger threshold
[{"id":"cb98f7ec.6b8a08","type":"Memory","z":"96bd11be.2cff3","name":"","x":284,"y":497,"wires":[["7c2d3760.aa1518"]]},{"id":"7c2d3760.aa1518","type":"jsonpath","z":"96bd11be.2cff3","expression":"memusage","split":true,"name":"Extract usage","x":457.99997329711914,"y":496.514009475708,"wires":[["dddd676c.1d5af8"]]},{"id":"87bf4a54.f6c6f8","type":"interval","z":"96bd11be.2cff3","name":"interval","interval":"1","onstart":false,"msg":"ping","showstatus":false,"unit":"seconds","statusformat":"YYYY-MM-D HH:mm:ss","x":137.28126525878906,"y":496.97222900390625,"wires":[["cb98f7ec.6b8a08"]]},{"id":"dddd676c.1d5af8","type":"switch","z":"96bd11be.2cff3","name":"> 90 %","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"90","vt":"num"}],"checkall":"true","outputs":1,"x":638.5001983642578,"y":496.3334445953369,"wires":[["d1c6f6a0.bab2d8"]]},{"id":"d1c6f6a0.bab2d8","type":"gc-trigger","z":"96bd11be.2cff3","display":true,"name":"","x":801.1667098999023,"y":496.3334045410156,"wires":[[]]}]
The memory consumption will look like this now:
GC trigger monitor
Caution
Keep in mind that this node is only a workaround, and not a real solution of the problem! A major garbage collection can take e.g. 100 msec, which means you get gaps in your processing.
Version: 0.0.1
Updated 9 years, 5 months ago
Rating: 0.0
31 in the last week
  • gc-trigger
  • garbage
  • memory
  • heap
  • clean
