node-red-contrib-gate-plus 0.1.3
A Node-RED gate node that routes blocked messages to a second output instead of discarding them.
npm install node-red-contrib-gate-plus
A Node-RED gate node with two outputs: one for messages that pass through while open, and one for messages that arrive while closed — so you can still do something with a blocked message instead of losing it.
This node was inspired by the excellent node-red-contrib-simple-gate by M. I. Bell, which discards messages while closed. If you want blocked messages queued and replayed later rather than routed live, that node's companion node-red-contrib-queue-gate is worth a look too. gate-plus is a fresh implementation with an overlapping feature set, released separately under Apache-2.0.
From your Node-RED user directory (typically ~/.node-red):
Or use the Manage Palette command in the Node-RED editor.
The node has one input and two outputs:
  • Output 1 ("open") — the message, passed straight through, when the gate is open.
  • Output 2 ("blocked") — the message, routed here instead of being discarded, when the gate is closed.
Messages whose msg.topic matches the configured Control Topic (default control) are never sent to either output — they're used only to change the gate's state. Recognised control payloads (each customisable, case-insensitive):
Command Effect
open Opens the gate
close Closes the gate
toggle Flips the current state
default Resets to the configured Default State
status Refreshes the node's status indicator
State persistence
Tick Restore from state saved in and choose a context store to persist the gate's state across redeploys and Node-RED restarts. If no valid saved state is found, the node falls back to Default State.
Example
[inject] --> [gate-plus] --output 1 (open)----> [normal processing]
                        \--output 2 (blocked)--> [logging / alerting / anything else]
[open/close/toggle inject] --topic: control--> [gate-plus]
Apache-2.0
Version: 0.1.3
Updated 4 months ago
Rating: 5.0 2
374 in the last week
  • gate-plus
  • gate
  • flow-control
  • utility
