node-red-contrib-game_controllerizer 0.3.10
Node-RED nodes for GameControllerizer
npm install node-red-contrib-game_controllerizer
Node-RED nodes for GameControllerizer.
These nodes allow users to combine the processes of IoT devices, Web services, and applications of AI, and to convert them into game control operations to augment existing digital games.
See our paper for more details.
Block diagram
block diagram
Getting Started
This assumes you have Node-RED already installed and working. This requires,
Install via Node-RED Manage Palette
Install via npm
$ cd ~/.node-red
$ npm install node-red-contrib-game_controllerizer
# then restart node-red
Cheat sheet
Import this json as a Node-RED flow.
Usage examples
Example 1
Send control operations (ex. push button-A) to a game console via the H/W gamepad emulator. Do not forget to configure input/output UART node.
flow1
flow data
[{"id":"72540d54.4285f4","type":"inject","z":"24c06ae6.309316","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":380,"wires":[["96f8637f.a373a"]]},{"id":"9aae373d.e1c218","type":"serial out","z":"24c06ae6.309316","name":"UART","serial":"b33fb905.04c2b","x":650,"y":400,"wires":[]},{"id":"96f8637f.a373a","type":"button","z":"24c06ae6.309316","name":"","button":0,"mode":"push","x":280,"y":380,"wires":[["97b5eb7d.8feaa"]]},{"id":"5ad63d0b.f5c9e4","type":"inject","z":"24c06ae6.309316","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":420,"wires":[["82fb165b.94fc38"]]},{"id":"82fb165b.94fc38","type":"dpad","z":"24c06ae6.309316","name":"","dpad":"2","mode":"3","x":280,"y":420,"wires":[["97b5eb7d.8feaa"]]},{"id":"97b5eb7d.8feaa","type":"binary-serializer","z":"24c06ae6.309316","name":"","x":480,"y":400,"wires":[["9aae373d.e1c218"]]},{"id":"b33fb905.04c2b","type":"serial-port","z":"","serialport":"/dev/ttyAMA0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"bin","out":"char","addchar":false,"responsetimeout":"10000"}]
Example 2
Send a Street Figher 2 "Hadouken" comamnd to a game console in response to the HTTP get request. You can use JSON based abstract format DSL4GC (Domain-specific Language for Game Control) for command descriptions. See hadouken function node for example.
flow2
flow data
[{"id":"9a40e17c.c1af4","type":"serial out","z":"24c06ae6.309316","name":"UART","serial":"e8720150.5629d","x":650,"y":160,"wires":[]},{"id":"fd7715d3.54b788","type":"function","z":"24c06ae6.309316","name":"hadouken","func":"msg.payload = [\n    {\"dpad\": 2, \"dur\":3},\n    {\"dpad\": 3, \"dur\":3},\n    {\"dpad\": 6, \"dur\":3},\n    {\"btn\" : [0], \"dur\": 3}\n];\n\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":160,"wires":[["ae3df6ef.dc3fe"]]},{"id":"a2ce9aa1.67f12","type":"http in","z":"24c06ae6.309316","name":"","url":"/hadouken","method":"get","upload":false,"swaggerDoc":"","x":120,"y":160,"wires":[["fd7715d3.54b788","bef21cc2.1c786"]]},{"id":"bef21cc2.1c786","type":"http response","z":"24c06ae6.309316","name":"http response","statusCode":"","headers":{"Access-Control-Allow-Origin":"*"},"x":320,"y":200,"wires":[]},{"id":"ae3df6ef.dc3fe","type":"binary-serializer","z":"24c06ae6.309316","name":"","x":480,"y":160,"wires":[["9a40e17c.c1af4"]]},{"id":"e8720150.5629d","type":"serial-port","z":"","serialport":"/dev/ttyAMA0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"bin","out":"char","addchar":false,"responsetimeout":"10000"}]
Example 3
Redirect control operations from a general gamepad to a game console. GcScannerJs, a helper software for GameControllerizer, converts general gamepad operations to DSL4GC, then sends it to Node-RED via Websocket/MQTT.
flow3
flow data
[{"id":"2af3b0eb.387578","type":"serial out","z":"24c06ae6.309316","name":"UART","serial":"58598bf4.c908ec","x":650,"y":260,"wires":[]},{"id":"46ffafc1.409c3","type":"websocket in","z":"24c06ae6.309316","name":"","server":"9cb3c35c.a2fd9","client":"","x":120,"y":260,"wires":[["b26d49d7.723b8"]]},{"id":"b26d49d7.723b8","type":"json","z":"24c06ae6.309316","name":"","property":"payload","action":"obj","pretty":false,"x":290,"y":260,"wires":[["2a433803.5452f"]]},{"id":"897e21a4.1f3c3","type":"websocket in","z":"24c06ae6.309316","name":"","server":"3bc89e3a.806bba","client":"","x":110,"y":300,"wires":[[]]},{"id":"cc8d93d9.90b52","type":"websocket in","z":"24c06ae6.309316","name":"","server":"bf28459.50a72b8","client":"","x":110,"y":340,"wires":[[]]},{"id":"2a433803.5452f","type":"binary-serializer","z":"24c06ae6.309316","name":"","x":480,"y":260,"wires":[["2af3b0eb.387578"]]},{"id":"58598bf4.c908ec","type":"serial-port","z":"","serialport":"/dev/ttyAMA0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"bin","out":"char","addchar":false,"responsetimeout":"10000"},{"id":"9cb3c35c.a2fd9","type":"websocket-listener","z":"","path":"/gamepad","wholemsg":"false"},{"id":"3bc89e3a.806bba","type":"websocket-listener","z":"","path":"/mouse","wholemsg":"false"},{"id":"bf28459.50a72b8","type":"websocket-listener","z":"","path":"/keyboard","wholemsg":"false"}]
Example 4
Receive a event from a H/W gamepad emulator that has 4 tactile switches on it. You can use an event like a injection node.
flow4
flow data
[{"id":"5b72539c.63192c","type":"serial in","z":"24c06ae6.309316","name":"UART","serial":"ec13252.94341d8","x":90,"y":440,"wires":[["954fa243.00c0b8"]]},{"id":"954fa243.00c0b8","type":"function","z":"24c06ae6.309316","name":"decode button input","func":"var tId = msg.payload.readUInt8(0);\n\nswitch(tId){\n    case 0x01:\n        return [{}, null, null, null];\n    case 0x02:\n        return [null, {}, null, null];\n    case 0x04:\n        return [null, null, {}, null];\n    case 0x08:\n        return [null, null, null, {}];\n}\n","outputs":4,"noerr":0,"x":290,"y":440,"wires":[[],[],[],[]]},{"id":"ec13252.94341d8","type":"serial-port","z":"","serialport":"/dev/ttyAMA0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"bin","out":"char","addchar":false}]
Version: 0.3.10
Updated 7 years, 4 months ago
47 in the last week
  • gamepad
  • button
  • dpad
  • stick
  • input-config
  • interrupt
  • wait
  • binary-serializer
  • game
  • controllerizer
  • control
