node-red-contrib-gaianode 1.6.3
Set of nodes for interfacing with the GAIA Platform
npm install node-red-contrib-gaianode
Gaia Nodes
Set of nodes for interfacing with the GAIA Platform (mostly Sparkworks API v.1).
GAIA (Green Awareness In Action) is a three year long, EU-funded H2020 project made up of nine partners. This project aims to promote positive behavioural changes within communities regarding energy consumption/awareness. Our activities will consist of the gamification of real-time, IoT-enhanced energy consumption metrics in trial schools located in Italy, Greece and Sweden.
Access requires a valid Sparkworks account (see Configuration)
You can install gaianodes directly using the editor i.e. the web interface. To do this select Manage Palette from the menu (top right), and then select the install tab in the palette. You can now search for new nodes to install, just type gaianode and select node-red-contrib-gaianode. After a while the new nodes will appear in the left panel under the group Gaia.
Otherwise you can install gaianodes within your user data directory (by default, %HOME%/.node-red) by typing:
cd %HOME%/.node-red
Available nodes
  • LatestValue: retrieves the latest value (with some additional informaion) of the resource identified by the id given to the node
  • Summary: retrieves the summary (latest value, averages, min, max, latest values at different granularities) of the resource identified by the id given to the node
  • RealTime: connects to the websocket output of the Gaia Platform allowing to receive real time unprocessed data as injected into the platform by the sensors
  • Notifications: connects to the websocket output of the Gaia Platform allowing to receive real time unprocessed data as injected into the platform by the sensors
  • ListResources: list the resources (sensors) associated with the given site id
  • Timerange: retrieve the values in the specified time window at the specified granularity (5min, hour, day, month) for the given resource
  • PushValue: push a value into the Gaia Platform (a valid virtual sensor id is needed, see BMS manual for infromation)
  • Uri2Id: convert the given URI to a numeric resource id to be used with other GaiaNodes
LatestValue
Parameters
  • Resource id: numerid id or a mustache-style string (e.g. {{msg.payload}})
  • Gaia Server: a configured Gaia Server
Output
  • payload
    • uri: Literal identifier of the resource
    • uom: The Unit of measurement
    • latestTime: The Timestamp of the measurement in milliseconds (UNIX time)
    • latest: The latest value measured
    • latestMin5: The averaged value during the latest 5 minutes
    • latestMin60: The averaged value during the latest hour
    • latestDay: The averaged value during the latest day
    • latestMonth: The averaged value during the latest month
  • topic: The id of the queried resource
Details
The queried resource can be configured writing directly its id (e.g. 155076) or by using mustache-style tags (e.g. {{msg.payload.id}} or {{msg.payload.resource}} for accessing the fields of the input message)
Summary
Retrieves the summary for the given resource id from the GAIA Platform
Output
  • payload
    • minutes5: Array containing the latest 48 values at 5 minutes interval
    • minutes60: Array containing the latest 48 values at one hour interval
    • day: Array containing the latest 48 values at one day interval
    • month: Array containing the latest 48 values at one month interval
    • min: Minimum value of the latest (5 minutes, hour, day, month)
    • max: Maximum value of the latest (5 minutes, hour, day, month)
    • max: Mean value of the latest (5 minutes, hour, day, month)
Timerange
Retrieves the values of the given resource within the specified time window.
Parameters
  • From: a date and time or a mustache-style string (e.g. {{msg.payload.from}}) in the format 2010/08/17 12:09:36
  • To: a date and time or a mustache-style string (e.g. {{msg.payload.to}}) in the format 2010/08/17 12:09:36
  • Granularity: the interval between queried values (5 minutes, 1 hour, 1 day, 1 month)
Output
  • payload is a dictionary whose key are the ids of the requested resources (currently only one resource at a time is supported)
    • average: Average of the values in the time range
    • summary: Sum of the values in the time range
    • data: Array of measurements. Each element contains:
      • reading: measurement value
      • timestamp: UNIX timestamp of the reading (milliseconds)
PushValue
Send a value to the specified resource (Virtual sensor) on the Gaia platform. Virtual sensors can be created using the Gaia BMS application.
Parameters
Creation of a virtual sensor
You can refer to the BMS - User Guide pages 14-15. Issue Currently the best way for retrieving the resource id of a Virtual Sensor is to open its page (by clicking on the sensor) and take the id from the URL shown in the browser (e.g. *http://bms.gaia-project.eu/#/page/sensor/view/**1000565** * )
Uri2Id
This node converts the textual URI of a resource to a numeric resource id to be used into the other gaia nodes.
Parameters
  • Resource id: textual URI or a mustache-style string (e.g. {{msg.payload.uri}})
Output
  • payload contains the numeric id of the resource identified by the provided URI
ListResource
Retrieves the list of available resources given a site identifier
Parameters
  • Site id: numerid id or the site you want whose resources will be listed or a mustache-style string (e.g. {{msg.site}})
Output
    • resources: An array of resources (sensors in this case) each one composed by:
      • resourceId: The numeric id of the resource
      • uri: The URI of the resource
      • name: The name of the resource
      • isa: the type of resource (e.g., sensor)
      • property: Measured property (e.g., Temperature, Luminosity)
      • uom: Unit of measurement (e.g., Wh, A, Raw)
  • options An array of key-value couple. The key is the URI of the resource and the value id the numeric id. This is usefull for creating selection widgets (e.g., for letting hte user choose in the GUI the resource to be read)
RealTime
Experimental Connects to the GAIA platform to receive real time measurements as soon as they are pushed to the platform
Parameters
  • Path: the path of the school/area to monitor (e.g. ROOT.GAIA.GROUPS.155076 where 155076 is the site id of the school)
Output
The message received by the platform are forwarded in real-time without post processing (e.g. cleaning, aggregation):
  • payload:
    • timestamp: The Timestamp of the measurement in milliseconds (UNIX time)
    • resourceUri: URI of the resource
    • value: Value read by the sensor
Notifications
Experimental Connects to the GAIA Recommendation engine and listen for real time notifications
Parameters
Output
  • payload: the textual recommendation sent by the engine
  • notification contains:
    • timestamp: Timestamp of the event (UNIX time)
    • school: Identifier of the school the rule belongs to
    • area: Identifier of the area to which the rule is linked
    • ruleClass: Name of the class of the rule
    • ruleName: Name of the rule (the instance of the rule)
    • ruleId: Id of the rule
    • values: Object containing a snapshot of the values when the rule has been fired
    • description: Brief description of the rule
    • suggestion: Same content of payload
    • type: The type of message received (e.g., info, alert)
To use the Gaia Nodes we must create a Gaia Server (one server can be used by multiple nodes). From the configuration of first Gaia node you insert you must chose one valid Gaia server, if don't have any configured click on the edit button
The Gaia server configuration window will open and you have just to enter your credentials and press Add From this moment you will find this server in the dropdown menu of each Gaia node.
Details
Paramters can be configured in the node configuration typing its id (e.g. 155076) or, where specified, by using mustache-style tags (e.g. {{msg.payload.id}} or {{msg.payload.resource}} for accessing the fields of the input message). It is also possible to configure the timestamp associated with the value by using the Time field in the node configuration; you can use mustache-style tags for accessing the field of the message to be used as timestamp (e.g. {{msg.payload.timestamp}} ).
Mustache
Gaia API
Gaia Android Application Android >= 7.0
Gaia Android Virtual Sensor
Version: 1.6.3
Updated 8 years, 2 months ago
License: CC BY 3.0
14 in the last week
  • LatestValue
  • Timerange
  • PushValue
  • Summary
  • RealTime
  • ListResources
  • Notifications
  • Uri2Id
  • gaia-server
