node-red-contrib-gactions-fulfillment 2.3.2
Node-RED nodes for creating webhook fulfillments for the Google Assistant.
npm install node-red-contrib-gactions-fulfillment
Node-RED Google Actions Fulfillment
npm GitHub Release Date Node-RED Library GitHub license
These Node-RED nodes enable Node-RED to serve as a webhook fulfimment endpoint for Google Actions. With them you can interact with Google Actions.
Switch to your Node-RED directory, e.g. ~/.node-red and type:
This will install this package for your Node-RED instance.
Google Actions In
This node acts as an entry point for a Google Action with the given handler. When a Google Actions webhook tries to call your Node-RED server (handler) as a fulfillment server/method this node is called initially if it's handler matches the requested handler.
Outputs
This node has only one output, an object named conversation with information for the action like parameters, language and more. This data is needed for the Google Actions Out node. Without it the node cannot send a response.
(stored as properties of the msg.conversation object)
  • handler
    • The requested handler
  • sessionID
    • The conversation's id
    • Used internally to identify different conversations in flows
  • lang
    • The language code requested with the action
    • E.g. 'de-DE' for german
  • intent
    • The sent intent object
    • with name, params and query
  • response
    • The internal response object to be sent back to the action
    • Used internally, direct editing is not recommended
Google Actions Language
This node switches between the given languages according to the conversation's language.
Inputs
(stored as properties of the msg object)
  • conversation
    • The conversation object (automatically set when originating from a Google Action In node).
Outputs
  • conversation
Google Actions Speak
This node adds a spoken string to the reponse. The spoken message comes from msg.payload.
Inputs
  • payload
    • The string to be spoken.
  • conversation
Outputs
  • payload
    • The sent message
  • conversation
    • The used conversation object
Google Actions Media
This node adds media to the reponse. This media can be an audio file or other supported media types but support for further types is planned for the future.
Inputs
  • conversation
Outputs
  • conversation
Google Actions Out
This node sends a response back to the action. It does not do much on it's own, e.g. spoken messages have to be added by a Google Action Speak node.
Inputs
  • conversation
  1. Install the package using any method to your Node-RED instance (see above).
  2. The nodes should be shown in the Google Assistant section.
  3. Add a Google Actions In node as an entrypoint for the fulfillment.
  4. Design your flow. Use Google Actions Speak for adding messages to the response.
  5. Add a Google Actions Out at the end of the flow. Remember to keep the conversation object during the flow.
  6. Configure the endpoint. In the Google Actions In node you can configure one. Add an unused port, a URL to be used and informations regarding the SSL certificate (See below for more information on that).
  7. Test it. Use a tool for HTTP(S) requests of your choice, e.g. curl, and send an example request:
curl --insecure -X POST -H "Content-Type: application/json" -d '{"handler":{"name":"ExampleHeader"},"intent":{"name":"actions.intent.BRUH","params":{},"query":""},"scene":{"name":"SceneName","slotFillingStatus":"UNSPECIFIED","slots":{}},"session":{"id":"session_id_69420","params":{},"typeOverrides":[]},"user":{"locale":"en-US","params":{"verificationStatus":"VERIFIED"}},"home":{"params":{}},"device":{"capabilities":["SPEECH","RICH_RESPONSE","LONG_FORM_AUDIO"]}}' https://localhost:8090/fulfillment
SSL
According to Google's webhook requirements you need a valid SSL certificate for your server in order to be accessible by an action. This certificate can be set easily per endpoint as specified above. For obtaining a SSL certificate for your server there are several options:
  • Using a DNS adress and Let's Encrypt
    • When you have a DNS adress for your server or home adress (you will need one) you can get a SSL Certificate for free using the Service Let's Enrypt with the application certbot
    • I would advise you to spin up a temporary NGINX-Server for obtaining it and then just keep the certificate with the key. Those can then be used in the application.
    • There are plenty tutorials on how to do so
It is planned to add an option for the nodes to use an HTTP server so this HTTP service can be forwarded then to services like ngrok. Due to time limitations this functionality has not been implemented yet but is planned for the future.
Version: 2.3.2
Updated 6 years, 3 months ago
Rating: 0.0
  • Google Actions Server
  • Google Actions In
  • Google Actions Language
  • Google Actions Media
  • Google Actions Speak
  • Google Actions Out
  • google
  • google actions
  • google assistant
  • chatbot
  • chat
