node-red-contrib-futurehome 1.0.1
Futurehome nodes for node-red
npm install node-red-contrib-futurehome
Release npm
This module provides a set of nodes in Node-RED to controll a Futurehome system. This was made using Futurehome's public API.
To install the stable version use the Menu - Manage palette option and search for node-red-contrib-futurehome, or run the following command in your Node-RED user directory (typically ~/.node-red):
npm i node-red-contrib-futurehome
There are a total of 5 nodes. Two used for connecting to the system using websocket, three used for sending different commands to the system.
connect to site
This node is used to connect to a Futurehome site, and output the data comming from the site. The data can be anything from a device changing state, a mode change, or the temperature setpoint in a room.
connect to device
There is currently a problem with the Futurehome API, so this node will not receive any data.
This node is used to connect to a device in the Futurehome system, and output changes from the device. This can be a magnet contact reporting open/close state, a motion sensor reporting motion, or a light turing on/off.
change mode
This node is used to change between the 4 modes in Futurehome. The mode can be defined on the node, or overwritten by payload.
// Send the following payload to use the node.
msg.payload = {"mode":"home"};        // changes to home mode
msg.payload = {"mode":"away"};        // changes to away mode
msg.payload = {"mode":"sleep"};        // changes to sleep mode
msg.payload = {"mode":"vacation"};    // changes to vacation mode
change a device
This node is used to change the state of a device. Dim or turn on/off a light.
// Turn device ON or OFF:
msg.payload = "on";            // turn on a device
msg.payload = "off";        // turn off a device
msg.payload = {"power":"on"};        // turn on a device
msg.payload = {"power":"off"};    // turn off a device
// Dim a device to %:
msg.payload = 35;        // dim a device to 35%
msg.payload = {"dimValue":"75"};    // dim a device to 75%
run shortcut
This node is used to run a shortcut in the system.
// If msg.payload is an int the node will try to run the shortcut with that ID.
msg.payload = 3;        // will run shortcut with ID = 3
// Anything else will run the shortcut selected on the node.
Version: 1.0.1
Updated 3 days ago
4 in the last day
73 in the last week
97 in the last month
  • futurehome-login
  • site
  • device
  • mode
  • change-device
  • shortcut
  • futurehome
  • smart home
  • iot
  • tskaard
