node-red-contrib-full-msg-json-schema-validation 1.1.0
JSON Schema validator for Node Red
npm install node-red-contrib-full-msg-json-schema-validation
node-red-contrib-json-full-schema-validator
JSON Full Schema validator for Node Red is pretty easy to use. Just open node properties and choose which property object wants to validate and paste JSON Schema
  • OK will returned in first response
  • KO will returned in second response. Error object with explanation will added in msg
JSON Schema:
{ "title": "Person", "type": "object", "required":["lastName"], "properties": { "firstName": { "type": "string", "description": "The person's first name." }, "lastName": { "type": "string", "description": "The person's last name." }, "age": { "description": "Age in years which must be equal to or greater than zero.", "type": "integer", "minimum": 0 } } }
Examples:
  • OK msg.payload= { "firstName": "John", "lastName": "Doe", "age": 1 };
  • KO msg.payload= { "firstName": "John", "age": 1 };
Version: 1.1.0
Updated 8 years, 3 months ago
241 in the last week
  • json-full-schema-validator
  • json
  • node
  • schema
