node-red-contrib-ftp-download 1.0.4
A Node-RED node for FTP downloading.
npm install node-red-contrib-ftp-download
A Node-RED node for FTP Downloads.
This node allows you to download one or more files within a single connection.
Files
The file paths may be defined in one of a number of ways.
  • msg.: A variable on the msg object that contains an array of Strings or source Objects.
  • flow.: A variable on the flow context object that contains an array of Strings or source Objects.
  • global.: A variable on the global context object that contains an array of Strings or source Objects.
  • json: A JSON array of Strings or source Objects.
  • string: A singular path String.
ex:
global.test = ["/path/to/ftp.file", "/path/to/another/ftp.file"];
// or
global.test = [
        "src": "/path/to/ftp.file",
        "dest": "/path/to/local.file"
        "src": "/path/to/another/ftp.file",
        "dest": "/path/to/another/local.file"
Directory
The directory path may be defined in one of a number of ways.
  • msg.: A variable on the msg object that contains a local path String.
  • flow.: A variable on the flow context object that contains a local path String
  • global.: A variable on the global context object that contains a local path String
  • string: A singular local path String.
The files defined in the files field will be downloaded into the directory field, if the files field is an array of objects with dest fields set. The final destination will be directory + "/" + file.dest
Output
An Array of local file path Strings. The "Output" variable may be set to define where the Array will be placed, by default msg.payload is used.
Acknowledgements
The node-red-contrib-ftp-download uses the following open source software:
  • node-ftp is an FTP client module for node.js that provides an asynchronous interface for communicating with an FTP server.
Version: 1.0.4
Updated 9 years, 7 months ago
License: Apache
26 in the last week
  • ftp-download-server
  • ftp-download
  • ftp
  • ftp-download
