node-red-contrib-freya 0.1.0
Custom nodes for Freya Vivarium Control System
npm install node-red-contrib-freya
Freya Banner
Node-RED is a visual programming tool that lets you wire together hardware, APIs, and online services by connecting blocks in a flow-based editor. The Freya Node-RED nodes lorem ipsum...
Install in Node-RED UI
ToDo
Manual install
On your device, navigate to the nodered folder, and run
License & Collaboration
Copyright© 2025 Sanne 'SpuQ' Santens. The Freya NodeRED nodes project is licensed under the MIT License. The Rules & Guidelines apply to the usage of the Freya Vivariums™ brand.
Collaboration
If you'd like to contribute to this project, please follow these guidelines:
  1. Fork the repository and create your branch from main.
  2. Make your changes and ensure they adhere to the project's coding style and conventions.
  3. Test your changes thoroughly.
  4. Ensure your commits are descriptive and well-documented.
  5. Open a pull request, describing the changes you've made and the problem or feature they address.
Version: 0.1.0
Updated 1 year ago
  • node-red-node
