node-red-contrib-focas 1.2.1
Node-RED Node to communicate with CNCs using Fanuc FOCAS protocol
npm install node-red-contrib-focas
Node-RED node designed for reading data from a Fanuc CNC using the FOCAS1/2 protocol.
This node was designed by ST-One. It depends on the @protocols/node-focas library that is currently only available bundled on the ST-One hardware.
The list below contains all functions currently supported by the node.
  • System Info: Reads status information of CNC
  • Status Info: Reads system information such as kind of CNC system, Machining(M) or Turning(T), series and version of CNC system software and number of controlled axes.
  • Timers: Gets cutting time, cycle time, and other timer data of CNC.
  • Axes Data: Reads various data related to servo axis/spindle axis.
  • Parameters: Reads the parameter specified.
  • Program Number: Reads program number of the program that is currently being selected on the CNC.
  • Sample Data: Samples data from CNC.
  • Alarm Messages: Reads currently active CNC alarm messages.
  • Read Macro: Reads the custom macro variable specified.
Version: 1.2.1
Rating: 2.0 5
7 in the last week
  • focas config
  • focas node
  • focas
  • fanuc
  • cnc
