node-red-contrib-flowtest 0.1.1
Simple testing for your Node-RED flows.
npm install node-red-contrib-flowtest
This package will add two new node types to your node palette.
  • test inject which will inject a test message into your flow.
  • ... and an assert node which will catch this test message and make assertions about it.
example-flow
A single test inject node can define multiple test cases. A test message will behave like a 'real' message. The only difference is that a test message will be catched by the first assert node. The assert node executes a callback to the test inject, where the assertion about the resulting message is done.
Run the test injection instant after re-deployment or with a message input. The test inject node will output the test result as debug output.
The nodes will give you a simple and intuitive feedback via node states.
Credits: I'm not the first who came up with this kind of design. During development I found these similar designs.
Define Test Cases
Test case script has to return an array ot test cases
return [<test-case-1>, <test-case-2>, ..., <test-case-n>]
example-flow
Test Case Object
label (string) : Test case label.
inject (object) : Test message.
assert (function(msg)) : Assert function. Define your test assertions with NodeJS - Assert or with should.
timeout (integer) : Timeout in miliseconds for the test case to timeout. Default is 2000ms, Max is 10000ms.
delay (integer) : Delay for the test case inject. Default is 100 ms.
Example
Test Case Script
return [{
  label: 'is lower case',
  inject: {
      payload: 'HELLO WORLD'
  assert: function(msg){
      should(msg).have.property('payload', 'hello world');
  label: 'msg payload is not null',
  inject: {
    payload: 'hello'
  assert: function(msg) {
      should(msg.payload).not.be.null();
  label: 'wrong data type',
  inject: {
      payload: 123
      should(msg).have.property('error');
flow.json
[{"id":"3ba5305cbc00e173","type":"tab","label":"Flow Test","disabled":false,"info":"","env":[]},{"id":"ffe853e065f4a8e9","type":"test inject","z":"3ba5305cbc00e173","name":"","onstart":true,"tests":"return [{\n    label: 'to lower case', \n    inject: {\n        payload: 'HELLO WORLD'\n    },\n    assert: function(msg){\n        should(msg).have.property('payload', 'hello world');\n    }\n}, {\n    label: 'msg payload not null',\n    inject: {\n        payload: 'hello'\n    },\n    assert: function(msg) {\n        should(msg.payload).not.be.null();\n    }\n},{\n    label: 'wrong data type', \n    inject: {\n        payload: 123\n    },\n    assert: function(msg) {\n        should(msg).have.property('error');\n    }\n}];","x":280,"y":180,"wires":[["f2f18ecdccead0a8"]]},{"id":"2ea8589458745f05","type":"inject","z":"3ba5305cbc00e173","name":"input","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"HELLO WORLD","payloadType":"str","x":290,"y":120,"wires":[["f2f18ecdccead0a8"]]},{"id":"f2f18ecdccead0a8","type":"function","z":"3ba5305cbc00e173","name":"to lower case","func":"msg.payload = msg.payload.toLowerCase();\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":140,"wires":[["1f2cbc42e45437fb"]]},{"id":"1f2cbc42e45437fb","type":"assert","z":"3ba5305cbc00e173","name":"","x":630,"y":140,"wires":[["2e6f285e437cb0dc"]]},{"id":"b2568a8b9019cf6d","type":"catch","z":"3ba5305cbc00e173","name":"","scope":null,"uncaught":false,"x":480,"y":220,"wires":[["5a29cf9d7e7d988c"]]},{"id":"5a29cf9d7e7d988c","type":"assert","z":"3ba5305cbc00e173","name":"","x":620,"y":220,"wires":[[]]},{"id":"2e6f285e437cb0dc","type":"debug","z":"3ba5305cbc00e173","name":"output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":760,"y":140,"wires":[]},{"id":"5900e6f16f05f5a6","type":"inject","z":"3ba5305cbc00e173","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":180,"wires":[["ffe853e065f4a8e9"]]}]
Version: 0.1.1
Updated 5 years, 3 months ago
404 in the last week
  • test inject
  • assert
  • test
  • flow
  • testing
  • assert
