node-red-contrib-flow-manager 0.7.4
Flow Manager separates your flow json to multiple files
npm install node-red-contrib-flow-manager
Flow Manager module for node-red
View change log
This assumes you have Node-RED already installed and working, if you need to install Node-RED see here
NOTE: This requires Node.js v14+
Install via Node-RED Manage Palette
Install via npm
$ cd ~/.node-red
$ npm install node-red-contrib-flow-manager
# Restart node-red
After installation of this module, during first boot only, A migration process will initiate.
During migration, your main flow json file will be split to multiple files which will store your node information.
It is advised to back up your main flow json, before running this module for the first time.
Node-RED startup process after migration:
All of your flow files are combined into a single JSON object, which is then loaded and served as your main flow object.
For that reason, it is advised to add your "fat" flow json file to .gitignore because from that moment, the flows are saved separately.
The nodes will be stored in the following subdirectories of your Node-RED path as such:
  • /flows/flow name
  • /subflows/subflow name
  • /config-nodes.json (global config nodes will be stored here)
It's a good idea to add these paths to your version control system.
Filter Flows
  • Allows selecting which flows Node-RED will load, and which will be ignored and not loaded, not only in Node-RED's UI, also in it's NodeJS process.
  • Unselected flows are NOT deleted, only "ignored" until you select them again using Filter Flows.
  • Filtering configuration is stored in flow-manager-cfg.json file under your Node-RED path.
  • if flow-manager-cfg.json file does not exist, or exists but malformed, or contains an empty JSON array, then all flows will be loaded and no filtering is done.
  • Filter Flows Popup
envnodes
envnodes allows configuration of nodes using an external source and custom logic.
example: create "envnodes/someName.jsonata" in your Node-RED project directory and put these contents:
     $config := require(basePath & "/someConfig.json");
       /* mqtt config node */
       "21bcf36a.891e4d": {
          "broker": $config.mqtt.broker,
          "port": $config.mqtt.port
       "name:MyInject": {
          "topic": "niceTopic"
The result would be that your mqtt config node will use values from an external configuration file (which is useful in some cases), And a topic value will be inserted to an inject node matched with the given name.
Note basePath is the path to your Node-RED directory.
When using Node-RED's "project mode", the value is the project folder path.
Supported envnode file ext: .jsonata .js .json when using .js you can either module.exports = {...} the object directly, or use a function/async function (for example to read external file) and return an object.
js example:
const fs = require('fs-extra');
module.exports = async function() {
    const configTopic = await fs.readJson('./config').topic;
    return {
        "name:MyInject": {
            "topic": configTopic
        "cff2a203.8158a": {
            "someProperty": "myProperty"
Attempting to change any envnode controlled property via Node-RED UI/AdminAPI will be cancelled (with a warning popup) to keep original values defined in your envnodes configuration.
EnvNodes Warning
Remote Deploy
Remote Deploy Button
If you work in a server-client environment, where you work locally on your flows, and once in a while need to push your local changes to a remote process running Node-RED.
Do the following to enable Remote Deployment feature:
  • Add remote definitions to flow-manager-cfg.json (you can add as many as you want, choose any name you wish for each remote)
        "filter": [],
        "fileFormat": "json",
        "remoteDeploy": {
          "remotes": [
              "name": "Production",
              "nrAddress": "http://yourAddress:1881"
              "name": "Staging",
              "nrAddress": "http://yourOtherAddress:1881"
  • Restart Node-RED
  • You should see the new "Remote Deploy" button on top of the Node-RED UI.
Remote Deploy Remote Selection
Remote Deploy Diff Tool
YAML flow file format
You can configure flow-manager to load/save flow files in YAML format instead oj JSON, by modifying file flow-manager-cfg.json as such:
  "fileFormat": "yaml"
The advantage is the code within function node becomes easier to read when inspecting the flow file itself.
See comparison below
YAML
- id: 493f0b3.b3b48f4
  type: function
  z: 70dd6be0.e35274
  func: |-
      const str = "hello";
      console.log(str + ' world');
      msg.payload = 'test';
  outputs: 1
  noerr: 0
  x: 580
  'y': 40
  wires:
JSON
    "id": "493f0b3.b3b48f4",
    "type": "function",
    "z": "70dd6be0.e35274",
    "name": "SomeFuncNode",
    "func": "const str = \"hello\";\nconsole.log(str + ' world');\nmsg.payload = 'test';\nreturn msg;",
    "outputs": 1,
    "noerr": 0,
    "x": 580,
    "y": 40,
flow-manager RESTful API
Get all flow names
curl --request GET \
  http://localhost:1880/flow-manager/flow-names
Response:
  ["Flow 1.json","Flow 2.json","Flow 3.json","Flow 4.json"]
Get flow-manager-cfg.json contents
  http://localhost:1880/flow-manager/cfg
get / change filter flows
get
  http://localhost:1880/flow-manager/filter-flows
change
curl --header "Content-Type: application/json" \
  --request PUT \
  --data '["Flow 1", "Flow 2"]' \
Modify flow files (add, update, delete any flow/subflow files)
Request URL template:
http://localhost:1880/flow-manager/flow-files/:type/:fileName?
type can be flow/subflow/global
can pass plural too: flows/subflows
Notice fileName is optional if you request "global" flow, leave out the fileName url part.
get
  http://localhost:1880/flow-manager/flow-files/flow/MyFlow
delete
curl --request DELETE \
add/update (mtime/atime query params are optional, in case you wish to set mtime "Modified Time" or atime "Access Time" after the file is written)
  --request POST \
  --data '[{"id":"d4366369.5303d","type":"tab","label":"NewFlow","disabled":false,"info":""}]' \
  http://localhost:1880/flow-manager/flow-files/flow/NewFlow
Example with mtime query param:
  --request POST \
  'http://localhost:1880/flow-manager/flow-files/flows/NewFlow?mtime=8/16/2020,%206:12:17%20PM'
On Demand flow loading using external RESTful requests
During runtime, you can request flow-manager to load any flow file placed in the flows directory,
by sending a POST request with the flows you wish to load (regardless of whether you configured any filter-flows or not)
Request to deploy all flows / redeploy current flows:
  --request POST \
  --data '{"action":"loadAll"/"reloadOnly" }' \
  http://localhost:1880/flow-manager/states
Request to add/remove/replace any flow:
  --request POST \
  --data '{"action":"addOndemand"/"removeOndemand"/"replaceOndemand" "flows":["Flow 1","Flow 2"] }' \
Retrieve flow states for all flows, subflows, and global nodes (config nodes)
Retrieve state for specific type and flow.
http://localhost:1880/flow-manager/states/:type/:flowName
Retrieve state for all flows of a given type.
Retrieve state for all flows/subflows/global.
:type can be subflow/flow/global (if global, there's no need for :flowName).
Example response for specific flow (http://localhost:1880/flow-manager/states/flow/Flow1)
    "deployed": true,
    "hasUpdate": true,
    "onDemand": false,
    "rev": "477a9952b50e161afdf2e4bb6b84ee31",
    "mtime": "2020-08-16T13:54:23.000Z",
    "oldRev": "54d163c840657920aaac705dadecae2b", // If hasUpdate
    "oldMtime": "2020-08-14T17:30:10.000Z" // If hasUpdate
  • deployed whether that flow file is deployed.
  • hasUpdate whether that flow file was changed externally, and can be deployed again to update.
  • onDemand whether that flow was deployed by an OnDemand request, and is not part of filtered flows selection.
  • rev/oldRev revision (checksum) of file.
  • mtime/oldMtime Modified Time of file.
Access flow-manager RESTful API on remotes defined in flow-manager-cfg.json
Request template:
http://localhost:1880/flow-manager/remotes/:remoteName/[append any rest endpoint here]
Example using flow-names
  http://localhost:1880/flow-manager/remotes/Production/flow-names
Version: 0.7.4
Updated 4 years, 5 months ago
Rating: 4.0 8
2714 in the last week
  • node
  • red
  • monogoto.io
  • monogoto
  • flow
  • manager
  • Alon
  • Amir
  • aabluedragon
