node-red-contrib-float2byte 1.0.2
Node-RED node to parse IEEE-754 Floating Point Number to byte array
npm install node-red-contrib-float2byte
Node Red node to convert IEEE-754 float point numbers to byte array
Input msg.payload can be a Number or a binary String (can be convert to number). Output msg.payload will be an Array of byte.
Version: 1.0.2
Updated 4 years, 3 months ago
7 in the last week
  • floatToByte
  • IEEE-754
  • Float32
  • Float
  • Converter
  • Decode
  • float to decimal
  • float to byte
