node-red-contrib-flightradar24 0.3.1
Node-RED node to fetch aircraft data from Flightradar24
npm install node-red-contrib-flightradar24
Node-RED node to retrieve plane locations from flightradar24 service.
Example
You can plot plane locations on map using node-red-contrib-web-worldmap.
https://raw.githubusercontent.com/kazuhitoyokoi/node-red-contrib-flightradar24/master/tokyo.gif
Example flow
https://raw.githubusercontent.com/kazuhitoyokoi/node-red-contrib-flightradar24/master/flow.png
[{"id":"76a1b73b.183d68","type":"inject","z":"ca1e6975.d266c8","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":100,"wires":[["16c80c68.7ba644"]]},{"id":"16c80c68.7ba644","type":"flightradar24","z":"ca1e6975.d266c8","lat":"51","latType":"num","lon":"-1.45","lonType":"num","name":"","x":130,"y":180,"wires":[["65d40db8.a06334","47e16a92.ac3384"]]},{"id":"65d40db8.a06334","type":"debug","z":"ca1e6975.d266c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":310,"y":140,"wires":[]},{"id":"47e16a92.ac3384","type":"worldmap","z":"ca1e6975.d266c8","name":"","lat":"","lon":"","zoom":"","layer":"","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"false","x":310,"y":220,"wires":[]}]
Version: 0.3.1
Updated 3 years ago
Rating: 4.7 3
50 in the last week
  • flightradar24
  • flight
  • flightradar24
