node-red-contrib-flight-recorder 0.2.1
A flight recorder for Node-RED flows: rolling message recordings, dumped as structured incidents on demand, on error, or on watermark match. Inline and tap capture, cockpit-style control node, crash-surviving persistence.
npm install node-red-contrib-flight-recorder
A flight recorder for Node-RED flows. The debug sidebar shows you the present; this shows you the moments leading up to a failure — a rolling recording of recent messages, dumped as a structured incident on demand, automatically when a node in scope reports an error, or when a message matches a watermark condition. With persistence enabled, the recording survives crashes and restarts, which is the part that truly earns the name.
Like real flight recorders, the nodes are orange.
The nodes
recorder (flight-recorder) — an inline recorder you drop onto a wire. Every message is captured onto the tape and forwarded untouched. Passthrough is sacred: the original message object, unmodified, always — no recording problem can ever block or alter traffic, and pausing the recorder stops the tape, never the flow. Its input carries traffic only; commands arrive exclusively through a control node.
recorder tap (flight-recorder-tap) — an ambient recorder that observes messages flowing through other nodes via the Node-RED messaging hooks, without touching their wires. Point its scope at flows, node ids, or node types (minus exclusions) and it records everything in scope. Drop one on a dedicated debug tab and you have a black box for the whole runtime. Supports automatic incident dumps when an in-scope node reports an error, and per-channel muting while the tape keeps rolling. Flight-recorder nodes themselves are always excluded from every scope — recorders never record recorders.
recorder control (flight-recorder-control) — the cockpit panel. An input-only node targeting one recorder; wire inject buttons into it to issue commands. Every command emits a receipt on its ack output, and results (incidents, query snapshots) appear on the target recorder's outputs, which stay the single source of truth for wiring.
recorder report (flight-recorder-report) — the post-mortem archiver. Wire it to any recorder output and it renders incidents as readable reports (summary plus a timeline with gap anomalies flagged, marks and restart boundaries in sequence position), query snapshots as status reports, and recorder events as one-line entries. Reports go to the message, to files in a directory of your choosing (text, Markdown, or self-contained HTML), or both — with an optional raw-JSON companion file sharing the same filename stem, so the readable report and its bit-for-bit evidence sit side by side. Collisions are suffixed rather than overwritten, and retention keeps the newest N incidents, pruning report and JSON as a pair. Tap with auto-error on → report node with a directory = every error becomes a dated post-mortem file, automatically.
Quick start
Install into your Node-RED user directory (typically ~/.node-red):
Restart Node-RED, then use Import → Examples → node-red-contrib-flight-recorder to load an example. Start with Simple Inline (drop a recorder on a wire, press dump, read the report) or Simple Tap (a flow that doesn't know it's being watched; error reports appear hands-free), then graduate to the Full Demo for watermarks, cockpit controls, pause/mark/mute and more. Every example works with zero configuration — deploy and watch the debug sidebar.
Commands
Sent as msg.payload (string, case-insensitive) to a control node, or directly to a tap's input:
dump emits the recording as a manual incident (msg.context is attached as incident context). clear empties the recording (sequence numbers are preserved — they are monotonic forever, across wraps, clears, and restarts). pause / resume stop and restart the tape; messages arriving while paused are counted, never silently lost. mark lays an annotation (msg.annotation) onto the tape in sequence position. query emits a status snapshot on the recorder's query output. mute / unmute (tap only) silence one channel — msg.target is { "node": "<id>" }, { "type": "mqtt in" }, or { "flow": "<tab id>" } — while everything else keeps recording; suppressed messages are counted, mute and unmute lay marks on the tape, and a muted source's errors still trigger auto-dump.
Manual dumps always fire. The configurable cooldown rate-limits only automatic incidents (error and watermark triggers), and every suppressed auto-dump is visible as an incidentSuppressed event — nothing is invisible.
Incidents and records
An incident carries its trigger (manual, error, or watermark), an encoded context, summary stats, and the records. Each record has a monotonic seq, capturedAt, deltaMs since the previous capture (restarts show up honestly as delta gaps), the source node (id, name, type, output port), redaction and truncation flags, and the encoded message. Oversized messages fall back to a summary form flagged truncated: true. Redaction paths are masked before anything is stored or previewed, so a secret can never leak into a truncated preview. Records recovered from disk after a restart carry restored: true.
Persistence
When enabled, recordings are written (debounced for captures, immediately for state changes) to <userDir>/flight-recorder/<nodeId>.json using atomic temp-file-and-rename writes — a crash mid-write can never corrupt an existing recording. Redeploys preserve the file; deleting the node removes it. Persistence failures are surfaced as events and never stop recording.
What the tap can and cannot see
Hooks observe messages between nodes: each record is a message a node sent. The tap cannot see inside a function node's logic, nor messages a node swallows without sending. Automatic error dumps rely on nodes reporting errors properly (node.error(err, msg)); a hard runtime crash fires no hook — that is precisely what persistence is for.
Tests
The package ships with its full harness suite (no framework, no Node-RED runtime required):
npm test
Apache-2.0
Version: 0.2.1
Updated 4 months, 1 week ago
  • flight-recorder
  • flight-recorder-tap
  • flight-recorder-control
  • flight-recorder-report
  • recorder
  • debug
  • debugging
  • logging
  • blackbox
  • black-box
  • diagnostics
  • incident
  • ring-buffer
  • flight-recorder
