node-red-contrib-fleet-agent 0.1.1
Node-RED agent for NR Fleet Manager (https://github.com/lotockii/nr-fleet-manager) — remote management via WebSocket
npm install node-red-contrib-fleet-agent
Node-RED agent for NR Fleet Manager — remote management of Node-RED instances via WebSocket.
Allows a central Fleet Manager server to monitor and control your Node-RED instances: restart/stop them, pull git updates, roll back commits, and receive real-time metrics.
Or via the Node-RED Manage Palette UI → search for node-red-contrib-fleet-agent.
fleet-agent-config (config node)
Stores the connection settings and maintains the persistent WebSocket connection to Fleet Manager.
Property Description
Fleet Manager URL WebSocket URL — supports str, flow, global, env types
Instance Name Label shown in Fleet Manager — supports str, flow, global, env, msg types
Token Source Direct (encrypted credential) or Environment Variable
Capabilities Checkboxes for permitted remote operations
fleet-agent (network node)
Handles incoming commands from Fleet Manager. Place it in your flow to activate the agent.
  • Input → triggers a status report on the output
  • Output → msg.payload with { connected, instanceName, capabilities, metrics }
Quick Start
  1. Install the package (see above)
  2. Add a Fleet Agent Config node (click the pencil icon inside the Fleet Agent node)
  3. Set Fleet Manager URL and Agent Token
  4. Enable the capabilities you want to allow
  5. Deploy — the agent connects automatically
Capabilities
Key Label Description
metrics Send Analytics / Metrics CPU, memory, uptime reporting
start Start Node-RED Allow remote start
stop Stop Node-RED Allow remote stop
restart Restart Node-RED Allow remote restart
users Manage NR Users View and sync Node-RED admin users
projects View Git Projects List Git projects and sync status
git_pull Git Pull Pull latest commits from git remote
git_rollback Git Rollback Roll back to a previous commit
Configuration Examples
Token via environment variable (recommended)
Token Source: Environment Variable
Env Variable Name: FLEET_AGENT_TOKEN
export FLEET_AGENT_TOKEN=your-secret-token
Token directly (stored encrypted)
Token Source: Direct (stored securely)
Agent Token: your-secret-token
The token is stored in Node-RED's encrypted credentials file — never in plain text.
Fleet Manager URL from environment
Fleet Manager URL type: env
Value: FLEET_MANAGER_URL
export FLEET_MANAGER_URL=ws://fleet.example.com:3001
Fleet Manager URL from global context
Fleet Manager URL type: global
Value: fleet.url
Set it in Node-RED global context (e.g. via functionGlobalContext in settings.js).
WebSocket Protocol
The agent uses a simple JSON protocol over WebSocket:
Agent → Fleet Manager
Message type When sent Key payload fields
register On connect instanceName, capabilities, nodeRedVersion, nodeVersion, uptimeSeconds
heartbeat Every 30 s uptimeSeconds, memoryMB, memoryTotalMB, nodeRedVersion
command_result After command commandId, success, error?, result?
Fleet Manager → Agent
Message type Description Payload fields
command Execute an action commandId, action, params
action Required params Description
restart — Restart: systemd/pm2 — service restart; direct — watchdog re-launches after 2s
stop — Stop: systemd/pm2 — stop service; direct — process exits (no way to start from Fleet)
get_metrics — Returns system metrics
git_pull path, branch git pull origin <branch>
git_rollback path, commitHash git reset --hard <hash>
get_projects userDir? Scan for git repos in userDir
Recommendation for production → Run Node-RED under pm2 or systemd so that Start / Stop / Restart from Fleet Manager work reliably. In direct mode, Stop cannot be undone from Fleet (no Start).
Reconnection
The client uses exponential backoff on disconnect: 1s → 2s → 4s → 8s → 16s → 32s → max 60s
Troubleshooting
Node shows "no config" → Add a fleet-agent-config node and link it.
Node shows "no connection — check config" → Fleet Manager URL or Token is empty/invalid. Check the config node settings.
Node stays "connecting…" forever → Verify the Fleet Manager server is running and reachable at the configured URL. → Check that the token is correct. → Look at Node-RED logs for WebSocket errors.
git_pull / git_rollback fails → Ensure Node-RED has read/write access to the project path. → The path must contain a .git directory.
get_projects returns empty array → The userDir path does not contain any directories with a .git folder. → Default: ~/.node-red (or NODE_RED_HOME env var).
Direct mode: Stop vs Restart → Restart: A detached watchdog process starts Node-RED again after ~2s. Requires that the script path can be resolved (process.argv[1], node-red/red.js, or which node-red). If it cannot be resolved, use pm2 or systemd. → Stop: Process exits. There is no way to start Node-RED again from Fleet Manager (the agent is gone). Start it manually, via cron, or use pm2/systemd and the Start command instead.
ISC © Andrii Lototskyi
Version: 0.1.1
Updated 8 months, 2 weeks ago
  • fleet-agent-config
  • fleet-agent
  • fleet
  • management
  • agent
  • websocket
