node-red-contrib-fitbit 1.0.6
Adds Fitbit API nodes to Node-RED
npm install node-red-contrib-fitbit
Node-RED nodes that gets information from Fitbit
    npm install node-red-node-fitbit
Configure
When creating a configuration for Fitbit you will need to create an app on dev.fitbit.com with the following settings:
  • Callback Url: https:///fitbit-credentials/auth/callback
    • Please note the URL must be HTTPS (self-signed SSL works).
  • OAuth 2.0 Application Type: Server
Other settings are up to you.
One node that gets reports from Fitbit.
Query node
Fitbit query node supports several endpoints
  • Get Body Fat Logs
  • Get Body Time Series
  • Get Daily Activity Summary
  • Get Activity Time Series
  • Get Sleep Logs
  • Devices information
Depending on the endpoint selected the node will allow different inputs to filter the fitbit query.
Note
Node-RED does not currently have a way to update credential data at runtime. App credentials are stored with other credentails but OAuth2 tokens are saved to disk.
Version: 1.0.6
Updated 7 years ago
7 in the last week
  • fitbit-credentials
  • fitbit
  • fitbit
  • health
  • tracker
