node-red-contrib-firebase-realtime-database 1.0.9
Communicate with google firebase realtime database. These nodes use the new firebase-admin API and service account json is used for authentication.
npm install node-red-contrib-firebase-realtime-database
Upgrading to version 1.x.x
New versions starting from 1.0.0 externalize the admin configuration node, so you need to install node-red-contrib-firebase-admin-config before installing and using this node:
npm i node-red-contrib-firebase-admin-config
Also due to naming conflicts, some of the node names have been changed, if you seen a node is not found when starting Node-RED, just delete them from the editor and re-add them from the pallete.
Communicate with Google Firebase real-time database
These nodes support Set and Push operations, as well as watching for changes.
To run test, create a file in the test folder:
cd test && touch my-firebase-service-credential.json
Setup a firebase project, get and paste the service account json to this file.
Then do
npm run test
Version: 1.0.9
Updated 5 years, 4 months ago
Rating: 3.0 2
45 in the last week
  • firebase realtime database in
  • firebase realtime database out
  • firebase
  • node
