node-red-contrib-firebase-data 0.0.11
The simplest of simple nodes with firebase
npm install node-red-contrib-firebase-data
Introduction
I will briefly explain how to use Firebase methods. https://firebase.google.com/docs/reference/rest/database Basically implemented based on this API document.
Get Set Push Update Remove setpriority rename child path
Certificate
Access link firebase settings as below. After that, click button "Generate new private key" to download key https://console.firebase.google.com/u/0/project/`[your-project]`/settings/serviceaccounts/adminsdk
certificate
Edit node, choose Auth Type is JSON Web Token and input client Email and private Key from the file
certificate2
  1. Get method (GET) If you execute after setting the Child Path, the Child Path data will appear.
get-node
get-data-node
  1. Set method (PUT) After inputting data such as {"first": "Jack", "last": "Sparrow"}, if there is already data in the specified Child Path, that data will be lost and updated with the input data.
set-node
set-data-node
  1. Push method (POST) For example, Child Path is a list of users, enter {"user_number": "321", "name": "John"}. When executed, the new user will be added to the user list.
push-node
push-data-node
  1. Update method (PATCH) Update the existing data with the entered data.
update-node
update-data-node
  1. Remove method (DELETE) Delete Child Path.
remove-node
remove-data-node
  1. Set Priority and setwithPrioty methods (PATCH) This is because the Put method sets the priority for the child path. (Or to get the priority with GET)
setpriority-node
setpriority-data-node
  1. Rename child path
rename-node
rename-data-node
Version: 0.0.11
Updated 6 years, 4 months ago
Rating: 4.5 4
28 in the last week
  • addFirebase
  • firebaseCertificate
  • firebase
  • firebase-data
  • firebase data
  • firebase-data realtime
