node-red-contrib-firebase-admin 1.1.17
A node-red module that wraps the server-side admin SDK of firebase, firestore, et.c.
npm install node-red-contrib-firebase-admin
A node-red module that wraps the server-side admin SDK of firebase, firestore, cloud storage, et.c.
Overview
The main difference of this module and all other firebase/store modules for node-red is that it takes a service account credential token as configuration.
This means that the nodes can run outside of the normal security rules, in admin mode, which is useful when running on the back-end.
The configuration needs two parameters, the first is the text of the service account credentials private key file. This can be found by going to the firebase console, then to the cogwheel icon at the top left then to project settings and then "Service Accounts". Click "Generate new private key". The second parameter is the database url for the database. The url has has a format like "https://myprojectname.firebaseio.com" and can also be found in the above place in the firebase console.
After initializing, the reference to the firebase SDK is stored in the global context variable 'firebase', which can be used in any function like this;
let fb = global.get('firebase')
fb.firestore().doc('foo/bar').get().then((ref)=>{
    let d = ref.data()
    node.send( {payload: {data: d}});
The cloud-storage reference is also made available under the global context variable 'cloud-storage'.
Realtime Database (rtdb) Nodes
rtdb-get
Get data from a path in the rtdb database
input: {"payload": {"path": "foo/bar"}}
output: whatever data was at the path "foo/bar" in the rtdb database
rtdb-on
Set up a snapshot listsner for a path in the rtdb database
output: whatever data was at the path "foo/bar" in the rtdb database, when changed
rtdb-set
Set data at a path in the rtdb database. Use "on" snapshot so will fire every time the data at the path changes and so drive flow execution from that point.
input: {"payload": {"path": "foo/bar", "obj": {"the": "object"}}
rtdb-push
Pushes the new object onto an array under the path
rtdb-query
Set up a reactive query for a path in the rtdb database.
input: {"payload": {"path": "foo/bar", queries:[], on: "value}}
on: "value" (can also be "child_added", "child_removed", "child_changed", "child_moved"). If an "on" property is missing, on: "value" is assumed as default
Where each query is an object that can look like either of the following examples;
  • {"startAt": "foo"}
  • {"endAt": "bar"}
  • {"equalTo": "quux"}
  • {"orderBy": "child", "value": "height"} (can also be "key" or "value)
  • {"limitTo": "last", "value": 3} (can also be "first")
output: [an array of results for the query]
Firestore nodes
firestore-get
Get data from a document path in the firestore database
output: the document at the path "foo/bar" in the firestore database
firestore-on
Set up a snapshot listener fo a document path in the firestore database
output: the document at the path "foo/bar" in the firestore database, when changed
firestore-set
Set data at a path in the firestore database. Uses "onSnapshot" so will fire every time the data at the path changes and so drive flow execution from that point.
input: {"payload": {"path": "foo/bar"}, {"some": object, "foo": 17}}
firestore-add
Adds the new object under the collection the path describes and assigns it a random id
output: The id of the new document
firestore-query
Set up a reactive query for a collection in the firestore database.
input:
    "payload": {
        "path": "foo/bar",
        "queries":[],
        "limit": 7,
        "startAt": 4000,  // follows the orderBy property
        "endAt": 4050, // follows the orderBy property
        "orderBy": "shoeSize",
        "orderDirection": "asc", //default is "desc"
        "queries":[
            {"company", "==", "ACME"},
            {"createdAt", ">", 1560099394242}
output: An array of the results of the query.
Storage nodes
storage-read
Read file data from a file at a given path under a given cloud storage bucket. The default bucket to be used can be set in the general firebase SDK settings. If the payload defines an optional bucket property, it will override the default bucket settings.
input:
    "payload": {
        "bucket": "xyzzyz123.appspot.com",
        "path": "myFile.txt"
output: Buffer object containing the binary file contents. Can easily be converted to a string by calling toString() on the Buffer.
storage-write
Writes the content of JavaScript Buffer object to a file path in a storage bucket.
input:
    "payload": {
        "bucket": "abc.appspot.com", // optional, is otherwise set as node config
        "path": "foo/bar/baz.json", // optional, see above
        "contents": <Buffer obj>,
        "contentType": "application/json" }, // optional
        "metadata": { "very":"interesting"}, // optional
        "public": true, // optional
        "private": false // optional
output:
    "payload": {"success": true, "filename": "foo/bar.txt"}  // ot false if an error occurred
storage-list
Lists the contents of files in a bucket
If "path" is defined in the payload, only files beginning with that path will be returned. I fomitted, the root level of the bucket is listed. A path can also be deep likes this; "foo/bar/baz". "delimiter" is the charatcer used to delimit directory levels, "/" by default.
input:
    "payload": {
        "bucket": "xyzzyz123.appspot.com",  // optional
        "path": "directory1", // optional
        "delimiter": "/" // optional
output: An array of google cloud-storage File objects. If you take this output and send it to a function which outputs a payload like this;
{"files": array_of_File_obejcts}
The storage-read module will read all file contents and output an object of filename keyed Buffer objects instead of the normal one.
Auth nodes
TBD
Version: 1.1.17
Updated 7 years, 1 month ago
Rating: 4.0 2
86 in the last week
  • rtdb-set
  • rtdb-push
  • rtdb-get
  • rtdb-on
  • rtdb-query
  • firestore-set
  • firestore-add
  • firestore-get
  • firestore-on
  • firestore-query
  • firebase-config
  • flow-to-rtdb
  • rtdb-to-flow
  • storage-read
  • storage-write
  • storage-list
  • firebase
  • firestore
  • cloud storage
