node-red-contrib-fips-jwt-sign 1.1.0
Node-RED nodes for secure high-performance RS256 JWT signing and verification using FIPS-compatible OpenSSL crypto
npm install node-red-contrib-fips-jwt-sign
🔐 FIPS-compatible RS256 JWT signing & verification nodes for Node-RED
Built for high-load financial / PSP / integrations.
  • jwt-sign – RS256 signing with a private RSA key
  • jwt-verify – RS256 verification with a public RSA key
  • jwt-credential-package – generate an encrypted client credential package
All crypto is performed using Node.js crypto (OpenSSL 3.x),
fully in-memory and compatible with FIPS 140-3 when used with a FIPS-enabled OpenSSL build.
💡 Overview
This module is designed for secure, high-throughput JWT operations in:
  • Payment Service Providers (PSP)
  • Banking / fintech integrations
  • PCI DSS 4.0 environments
  • Backend-to-backend trusted communication
The module provides two Node-RED nodes:
  1. JWT Sign – create RS256-signed JWTs using a private RSA key
  2. JWT Verify – verify RS256 JWT signatures using a public RSA key
Both nodes:
  • Use RSA-SHA256 + PKCS#1 v1.5 (standard RS256)
  • Work 100% in memory (no temporary files, no subprocesses)
  • Are optimized for high-load scenarios (RSA key objects cached in memory)
  • Enforce strict signature rules (no alg:none, no algorithm downgrade)
🔐 Features
  • RS256 (RSA-SHA256) JWT signing
  • RS256 JWT verification
  • PKCS#1 v1.5 padding (compatible with financial APIs)
  • High-performance: key objects cached per node instance
  • 100% in-memory cryptography using OpenSSL 3.x
  • FIPS-compatible when Node.js uses a FIPS provider
  • Node.js ≥ 18, Node-RED ≥ 3.0
  • PCI DSS 4.0 friendly (Sections 3.5 / 3.6)
  • Secure Base64URL handling
  • Hardened JWT validation (header, payload, structure)
  • In-memory RSA credential generation and AES-256 ZIP packaging
Credential package node
jwt-credential-package accepts msg.credential_request.api_client_id and returns two objects:
  • msg.key_record contains the API key hash and public key for database storage.
  • msg.key_package contains a password-protected ZIP Buffer and its one-time password.
The plaintext API key and private key exist only while the node builds the archive. The private key is additionally encrypted as PKCS#8. Do not connect a Debug node configured to display the complete output message.
jwt-sign also accepts an optional msg.private_key_passphrase when signing with an encrypted PKCS#8 key. Set msg._wipe_private_key = true to remove both the PEM and passphrase from the message after loading the key.
📦 Installation
Version: 1.1.0
Updated 1 month, 2 weeks ago
4 in the last week
  • jwt-sign
  • jwt-verify
  • jwt
  • rs256
  • rsa
  • jsonwebtoken
  • signature
  • crypto
  • fips
  • fips140-3
  • pci-dss
  • openssl
  • security
  • cryptography
