node-red-contrib-filemaker 2.3.1
Node-RED FileMaker nodes. These nodes use the FileMaker Data API to connect with a FileMaker database.
npm install node-red-contrib-filemaker
Node-RED FileMaker nodes. These nodes use fms-api-client to connect to FileMaker Server. Each node exposes an fms-api-client method or utility. Nodes connecting to FileMaker Server depend upon a configurable FileMaker Data API client.
Project Information
npm version Build Status Coverage Status Known Vulnerabilities
The nodes in this project use fms-api-client to connect via the FileMaker Data API to FileMaker Server. The nodes that connect to FileMaker Server depend upon a configurable client node. The client node uses marpat to store and maintain FileMaker Data API session information in-memory, on the filesystem, or in a MongoDB cluster. Persistence is configured via Node-RED's settings file. For more information see the storage section. For security client configuration parameters are not exported with a flow.
Once configured a client node will automatically create and maintain a FileMaker Data API session as needed. You are not required to call the login or logout nodes in a flow.
Each node can be configured to use either static or dynamic parameters. Dynamic parameters may be read from either the msg property or the flow and global contexts. The default output of each node is msg.payload. A node can also be configured to merge its output with any property on the msg object.
:v: and :heart: - Lui de la Parra
Table of Contents
These nodes can be installed from the command line by running the following command in your Node-RED directory:
npm install --save node-red-contrib-filemaker
These nodes can also be installed using the Node-RED palette manager.
Storage
The nodes in this project all depend on a configurable Data API client. By default the client is saved in-memory. When saved in-memory a client will not persist between restarts of the Node-RED runtime. This means that each restart of the Node-RED runtime will cause the client to open new Data API sessions.
To persist a client between Node-RED runtime restarts and allow active session monitoring and maintenance additional datastores can be configured. This project will accept a url property and an options property from a marpat object in the Node-RED settings.js file. Any datastore made available by marpat. The url property accepts the following formats:
  • MongoDB:
    • Format: mongodb://[username:password@]host[:port][/db-name]
  • Filesystem:
    • Format: nedb://[directory-path]
  • In Memory:
    • Format: nedb://memory
Stroage Configuration Example:
module.exports = {
  // the tcp port that the Node-RED web server is listening on
  uiPort: process.env.PORT || 1880,
  marpat: { url: process.env.DATASTORE, options: {} }
File ./red.dev.config.js
Status Node
The status node will return the current state of the configured client. The status node will return the client's data usage, urls for all pending and queued requests, and currently open sessions.
Status Illustration
status Node
Status Flow
Status Flow
Login Node
The login node will open a FileMaker Data API session. This node will also save the resulting session token for future use by the configured client. You are not required to login before using any other node in a flow.
Login Illustration
Login Node
Login Flow
Example Flow
Logout Node
The logout node closes the currently open Data API session and removes the associated session token. You are not required to logout at the end of a flow.
Logout Illustration
Logout Node
Logout Flow
Logout Example Flow
Product Info Node
The product info node gets server product info. This node gets metadata for the FileMaker server the client is configured to use.
Product Info Illustration
Product Info Node
Product Info Flow
Product Info Example Flow
Databases Node
The databases node gets all the scripts and script folders accesible to the client.
Databases Illustration
Databases Node
Databases Flow
Databases Example Flow
Database Scripts Node
The database scripts node gets all the scripts and script folders accesible to the client.
Database Scripts Illustration
Database Scripts Flow
Database Scripts Example Flow
Database Layouts Node
The database layouts node gets all the layouts and layout folders accesible to the client.
Database Layouts Illustration
Database Layouts Flow
Database Layouts Example Flow
Layout Info Node
The layout info node gets metadata information for fields and portals on the specified layout.
Layout Info Illustration
Layout Info Node
Layout Info Flow
Layout Info Example Flow
Create Node
The create node creates a record in FileMaker. By default The create node will use the value in msg.payload.layout as the layout context and msg.payload.data for setting field and portal data.
Create Illustration
Create Node
Create Flow
Create Example Flow
Edit Node
The edit node edits a specific record in FileMaker. By default the edit node will use msg.payload.recordId as the record id to target for editing, the data found in msg.payload.data for editing field and portal data, and msg.payload.layout as the layout context.
Edit Illustration
Edit Node
Edit Flow
Edit Example Flow
Delete Node
The delete node deletes a specific record in FileMaker. By default the delete node will use msg.payload.recordId as the record id to target for deletion and msg.payload.layout as the layout context.
Delete Illustration
Delete Node
Delete Flow
Delete Example Flow
Get Node
The get node retrieves a specific FileMaker record. By default the get node will use msg.payload.layout as the layout context, and msg.payload.recordId as the record id to target.
Get Illustration
Get Node
Get Flow
Get Example Flow
Duplicate Node
Duplicate Illustration
Duplicate Node
Duplicate Flow
Duplicate Example Flow
List Node
The List node lists FileMaker records for a specified layout. By default the list node will use the value found in msg.payload.layout as the layout context.
List Illustration
List Node
List Flow
List Example Flow
Find Node
The find node performs a find in FileMaker. By Default the find node will user msg.payload.layout as the layout context, and msg.payload.query as query parameters for the find.
Find Illustration
Find Node
Find Flow
Find Example Flow
Script Node
The script node will trigger a script in FileMaker. By default the script node will use msg.payload.layout as the layout context, and msg.payload.script as the script to run. An optional script parameter may also be passed using msg.payload.parameter.
Script Illustration
Script Node
Script Flow
Script Example Flow
Upload Node
The upload node will transfer binary data to a FileMaker container. By default the upload node will use msg.payload.file as either a string path or buffer object and msg.payload.layout as the layout context.
Upload Illustration
Upload Node
Upload Flow
Upload Example Flow
Globals Node
The globals node will set global record field values for the current FileMaker session. The globals node will use msg.payload.data to set global fields.
Globals Illustration
Globals Node
Globals Flow
Globals Example Flow
Field Data Node
The field data node reduces the data found in msg.payload.data to only include the modId, recordId, and fieldData properties.
Field Data Illustration
Field Data Node
Field Data Flow
Field Data Example Flow
Record Ids Node
The record ids node reduces the data found in msg.payload.data to only include the recordId property.
Record Ids Illustration
Record Ids Node
Record Ids Flow
Record Ids Example Flow
Transform Node
The tranform node transforms data in msg.payload.data. It reduces { table::field : value } properties to { table: { field : value } } properties.
Transform Illustration
Transform Node
Transform Flow
Transform Example Flow
Container Data Node
The container node retrieves container data from msg.payload.data. The container node requires a container property, a filename property, and a destination property. Each property should be a dot notation path to the required data, such as fieldData.container and fieldData.fileName. If the configured path does not exist it will be automatically created.
Container Data Illustration
Containers Node
Container Data Flow
Containers Example Flow
Tests
npm install
npm test
> [email protected] test node-red-contrib-filemaker
> snyk test && nyc _mocha --recursive  "test/**/*_spec.js" --timeout=30000 --exit
Testing /node-red-contrib-filemaker...
Organization:      luidog
Package manager:   npm
Target file:       package-lock.json
Open source:       yes
Project path:      /node-red-contrib-filemaker
Local Snyk policy: found
Licenses:          enabled
✓ Tested 364 dependencies for known issues, no vulnerable paths found.
  Client Node
    Client Save
      ✓ should save on close
    Reused Client Tests
      ✓ should be loaded
      ✓ should create a persistent client (152ms)
      ✓ should reuse a client (113ms)
      ✓ should allow a client's server configuration to be modified
      ✓ should allow a client's database configuration to be modified
      ✓ should allow a client's account user configuration to be modified
      ✓ should allow a client's account password configuration to be modified
      ✓ should allow multiple clients
      ✓ should create a client of one does not exist
      ✓ should reuse a client if it exists
      ✓ should handle datastore errors
    New Client Tests
      ✓ should be loaded
      ✓ should create a persistent client (215ms)
  Container Data Node
    ✓ should be loaded
    ✓ should download an object with container data to a buffer (547ms)
    ✓ should download an array of objects with container data to a buffer (2579ms)
    ✓ should download an object with container data to the filesystem (1526ms)
    ✓ should download an array of objects with container data to the filesystem (1430ms)
    ✓ should throw an error with a message and a code when writing an object to a buffer and an error is triggered
    ✓ should throw an error with a message and a code when writing an array to a buffer an error is triggered
    ✓ should handle undefined data input when writing to a buffer
    ✓ should handle undefined data input when writing to a file
    ✓ should throw an error when writing data to the filesystem and an error is triggered
    ✓ should throw an error with a message and a code when writing to a buffer and an array is triggered
  Create Record Node
    ✓ should be loaded
    ✓ should create a record (208ms)
    ✓ should allow the filemaker response to be merged to the message object (308ms)
    ✓ should use flow context to create a record. (217ms)
    ✓ should use global context to create a record. (209ms)
    ✓ should throw an error with a message and a code (264ms)
  Databases Node
    ✓ should be loaded
    ✓ should return available databases (89ms)
    ✓ should reject with an error message and a code (115ms)
    ✓ should reject if a client can not be initialized
  Delete Record Node
    ✓ should be loaded
    ✓ should delete a record (345ms)
    ✓ should throw an error with a message and a code (214ms)
    ✓ should handle client initilization errors
  Duplicate Record Node
    ✓ should be loaded
    ✓ should duplicate a record (356ms)
    ✓ should reject with an error message and a code (206ms)
    ✓ should rehject with an error if the client cannot be initialized
  Edit Record Node
    ✓ should be loaded
    ✓ should edit a record (357ms)
    ✓ should support merging data when editing a record (356ms)
    ✓ should throw an error with a message and a code (225ms)
    ✓ should reject with an error if a client cannot be initialized
  FieldData Utility Node
    ✓ should be loaded
    ✓ should transform an array of objects (370ms)
    ✓ should transform a a single object (386ms)
    ✓ should reject with an error message and code
  Find Records Node
    ✓ should be loaded
    ✓ should perform a find (352ms)
    ✓ should handle client connection errors
    ✓ should handle client initialization errors
    ✓ allows multiple clients
    ✓ will reuse previous clients
    ✓ should throw an error with a message and a code (158ms)
  Get Record Node
    ✓ should be loaded
    ✓ should get a specific record (408ms)
    ✓ should throw an error with a message and a code (144ms)
  Set Globals Node
    ✓ should be loaded
    ✓ should set globals (169ms)
    ✓ should throw an error with a message and a code (162ms)
    ✓ should reject with an error if the client cannot be initialized
  Layout Info Node
    ✓ should be loaded
    ✓ should get layout information (168ms)
    ✓ should throw an error with a message and a code (172ms)
  Get Layouts Node
    ✓ should be loaded
    ✓ should return a list of layouts (168ms)
    ✓ should reject if a client cannot be initialized
  List Records Node
    ✓ should be loaded
    ✓ should List records (405ms)
    ✓ should throw an error with a message and a code (164ms)
  Login Node
    ✓ should be loaded
    ✓ should login to a Data API session (104ms)
    ✓ should throw an error with a message and a code (1437ms)
  Logout Node
    ✓ should be loaded
    ✓ should close a Data API Session (656ms)
    ✓ should throw an error if a client cannot be initialized
  Product Info Node
    ✓ should be loaded
    ✓ should return Data API Server Info (93ms)
    ✓ should reject with an error message and a code (102ms)
  Record Id Utility Node
    ✓ should be loaded
    ✓ should extract record ids from a single object (338ms)
    ✓ should extract record ids from an array of objects (258ms)
  Trigger Script Node
    ✓ should be loaded
    ✓ should trigger a script (193ms)
    ✓ should parse a script result if it is valid json (165ms)
    ✓ should not parse a script result if it is not valid json (182ms)
    ✓ should throw an error with a message and a code (274ms)
  Get Scripts Node
    ✓ should be loaded
    ✓ should return a list of scripts (176ms)
  Utility Services
    merge utility
      ✓ should merge data to the payload object
    sanitize utility
      ✓ should discard unspecified properties
    compact utility
      ✓ should accept an array of objects
      ✓ should remove null properties
      ✓ should remove empty strings
      ✓ should not remove false values
      ✓ should discard non json values
    isJson Utility
      ✓ it should return true for an object
      ✓ it should return true for an empty object
      ✓ it should return true for a stringified object
      ✓ it should return false for a number
      ✓ it should return false for undefined
      ✓ it should return false for a string
      ✓ it should return false for null
    castBoolean Utility
      ✓ it should cast a true string as true boolean
      ✓ it should cast a false string as false boolean
      ✓ it should cast multiple string values as booleans
      ✓ it should only cast strings of true or false
  Client Status Node
    ✓ should be loaded
    ✓ should return Data API Client Status
  Transform Utility Node
    ✓ should be loaded
    ✓ should transform an array of objects (411ms)
    ✓ should transform a single object (270ms)
  Upload File Node
    ✓ should be loaded
    ✓ should upload to an existing record (436ms)
    ✓ should upload to a file to a new record (1455ms)
  146 passing (1m)
File                   |  % Stmts | % Branch |  % Funcs |  % Lines | Uncovered Line #s |
All files              |      100 |      100 |      100 |      100 |                   |
 client                |      100 |      100 |      100 |      100 |                   |
  client.js            |      100 |      100 |      100 |      100 |                   |
 nodes                 |      100 |      100 |      100 |      100 |                   |
  containerData.js     |      100 |      100 |      100 |      100 |                   |
  create.js            |      100 |      100 |      100 |      100 |                   |
  databases.js         |      100 |      100 |      100 |      100 |                   |
  delete.js            |      100 |      100 |      100 |      100 |                   |
  duplicate.js         |      100 |      100 |      100 |      100 |                   |
  edit.js              |      100 |      100 |      100 |      100 |                   |
  fieldData.js         |      100 |      100 |      100 |      100 |                   |
  find.js              |      100 |      100 |      100 |      100 |                   |
  get.js               |      100 |      100 |      100 |      100 |                   |
  globals.js           |      100 |      100 |      100 |      100 |                   |
  layout.js            |      100 |      100 |      100 |      100 |                   |
  layouts.js           |      100 |      100 |      100 |      100 |                   |
  list.js              |      100 |      100 |      100 |      100 |                   |
  login.js             |      100 |      100 |      100 |      100 |                   |
  logout.js            |      100 |      100 |      100 |      100 |                   |
  productInfo.js       |      100 |      100 |      100 |      100 |                   |
  recordId.js          |      100 |      100 |      100 |      100 |                   |
  script.js            |      100 |      100 |      100 |      100 |                   |
  scripts.js           |      100 |      100 |      100 |      100 |                   |
  status.js            |      100 |      100 |      100 |      100 |                   |
  transform.js         |      100 |      100 |      100 |      100 |                   |
  upload.js            |      100 |      100 |      100 |      100 |                   |
 services              |      100 |      100 |      100 |      100 |                   |
  index.js             |      100 |      100 |      100 |      100 |                   |
  utilities.service.js |      100 |      100 |      100 |      100 |                   |
MIT © Lui de la Parra
Dependencies
  • fms-api-client: A FileMaker Data API client designed to allow easier interaction with a FileMaker database from a web environment.
  • fs-extra: fs-extra contains methods that aren't included in the vanilla Node.js fs package. Such as mkdir -p, cp -r, and rm -rf.
  • lodash: Lodash modular utilities.
  • marpat: A class-based ES6 ODM for Mongo-like databases.
Development Dependencies
  • chai: BDD/TDD assertion library for node.js and the browser. Test framework agnostic.
  • coveralls: takes json-cov output into stdin and POSTs to coveralls.io
  • dotenv: Loads environment variables from .env file
  • eslint: An AST-based pattern checker for JavaScript.
  • eslint-config-google: ESLint shareable config for the Google style
  • eslint-config-prettier: Turns off all rules that are unnecessary or might conflict with Prettier.
  • eslint-plugin-html: A ESLint plugin to lint and fix inline scripts contained in HTML files.
  • eslint-plugin-prettier: Runs prettier as an eslint rule
  • mocha: simple, flexible, fun test framework
  • mocha-lcov-reporter: LCOV reporter for Mocha
  • mos: A pluggable module that injects content into your markdown files via hidden JavaScript snippets
  • mos-plugin-dependencies: A mos plugin that creates dependencies sections
  • sinon: JavaScript test spies, stubs and mocks.
  • snyk: snyk library and cli utility
  • mos-plugin-execute: Mos plugin to inline a process output
  • mos-plugin-installation: A mos plugin for creating installation section
  • mos-plugin-license: A mos plugin for generating a license section
  • node-red: A visual tool for wiring the Internet of Things
  • node-red-node-test-helper: A test framework for Node-RED nodes
  • nyc: the Istanbul command line interface
  • pm2: Production process manager for Node.JS applications with a built-in load balancer.
  • prettier: Prettier is an opinionated code formatter
  • varium: A strict parser and validator of environment config variables
Version: 2.3.1
Updated 6 years, 7 months ago
Rating: 5.0 2
49 in the last week
  • dapi-client
  • dapi-product-info
  • dapi-databases
  • dapi-duplicate
  • dapi-layouts
  • dapi-layout
  • dapi-scripts
  • dapi-login
  • dapi-logout
  • dapi-create-record
  • dapi-edit-record
  • dapi-delete-record
  • dapi-get-record
  • dapi-status
  • dapi-list-records
  • dapi-perform-find
  • dapi-trigger-script
  • dapi-upload-file
  • dapi-set-globals
  • dapi-field-data
  • dapi-record-id
  • dapi-transform
  • dapi-container-data
  • FileMaker
  • Data API
  • Node-RED
  • fms-api-client
  • marpat
  • IOT
