node-red-contrib-file-template 1.1.5
A Node-RED node that loads HTML template content from the filesystem with automatic file watching, reloading, and built-in file editor
npm install node-red-contrib-file-template
A Node-RED node that loads HTML template content from the filesystem with automatic file watching and reloading, perfect for managing large template files externally.
  • 📁 File-based Templates: Load HTML templates from the filesystem instead of embedding them in flows
  • 🔄 Auto-reload: Automatically watches template files for changes and reloads content
  • 🎯 Mustache Support: Built-in support for Mustache/Handlebars-style variable substitution
  • 📊 Status Indicators: Visual feedback on file load status and errors
  • 🛡️ Error Handling: Graceful fallback to inline templates when files are unavailable
  • ⚡ Performance: Only reloads files when they actually change (based on modification time)
Via Node-RED Palette Manager
  1. Go to Node-RED settings → Manage Palette → Install
  2. Search for node-red-contrib-file-template
  3. Click Install
Via npm
Manual Installation
git clone https://github.com/danedens/node-red-contrib-file-template.git
cd node-red-contrib-file-template
npm install
npm link
npm link node-red-contrib-file-template
Basic Usage
  1. Drag the file-template node from the function category into your flow
  2. Double-click to configure:
    • Template File: Path to your HTML template file (e.g., templates/dashboard.html)
    • Template Data: Message property containing data for substitution (default: payload)
    • Template Format: Choose Handlebars/Mustache for variable substitution or Plain HTML
  3. Connect your data source to the input
  4. Connect the output to a dashboard template node or HTTP response
Configuration Options
Option Description Default
Name Node display name (auto-generated)
Template File Path to template file relative to Node-RED working directory required
Template Format handlebars for variable substitution, plain for static HTML handlebars
Template Data Message property containing template data payload
Output Set msg.template as string or parsed object str
Fallback Template Optional inline template if file loading fails (empty)
Example Flow
        "id": "template-node",
        "type": "file-template",
        "name": "Dashboard Template",
        "filename": "templates/TodoList.html",
        "format": "handlebars",
        "field": "payload",
        "fieldType": "msg",
        "output": "str"
Template Syntax
Variable Substitution
Use Mustache-style syntax for variable substitution:
Template File (templates/dashboard.html):
<div class="dashboard">
    <h1>{{title}}</h1>
    <p>Welcome, {{user.name}}!</p>
    <div class="stats">
        <span>Total Items: {{stats.total}}</span>
        <span>Completed: {{stats.completed}}</span>
    </div>
</div>
Input Message:
    "payload": {
        "title": "My Dashboard",
        "user": {
            "name": "John Doe"
        "stats": {
            "total": 25,
            "completed": 18
Output (msg.template):
    <h1>My Dashboard</h1>
    <p>Welcome, John Doe!</p>
    <div class="stats">
        <span>Total Items: 25</span>
        <span>Completed: 18</span>
    </div>
</div>
Nested Properties
Access nested object properties using dot notation:
<p>{{user.profile.email}}</p>
<p>{{settings.theme.primaryColor}}</p>
Default Values
If a variable doesn't exist, it will be replaced with an empty string:
<p>{{nonexistent.property}}</p>  <!-- Results in: <p></p> -->
File Watching
The node automatically watches your template files for changes:
  • ✅ File Modified: Automatically reloads content when you save changes
  • ⚠️ File Deleted: Shows warning status, falls back to inline template if available
  • 🔄 File Restored: Automatically detects when file is restored and reloads
  • 📊 Status Updates: Visual indicators show current file status
Status Indicators
Color Meaning
🟢 Green Template file loaded successfully
🟡 Yellow Using fallback inline template
🔴 Red Error loading file or processing template
⚪ Grey No file specified or node inactive
Output Format
The node adds the processed template to msg.template and includes metadata:
    "template": "<html>...</html>",  // Processed template content
    "_fileTemplate": {               // Metadata
        "filename": "templates/dashboard.html",
        "lastModified": 1640995200000,
        "length": 2048,
Use Cases
Dashboard Templates
Perfect for Node-RED dashboards with large HTML templates:
[data source] → [file-template] → [dashboard template]
Web Applications
Generate dynamic web pages:
[HTTP request] → [data processing] → [file-template] → [HTTP response]
Email Templates
Create dynamic email content:
[trigger] → [user data] → [file-template] → [email sender]
Report Generation
Generate HTML reports from data:
[database query] → [data formatting] → [file-template] → [PDF converter]
Advanced Features
Multiple Data Sources
Pull template data from different contexts:
  • msg - From incoming message (default)
  • flow - From flow context
  • global - From global context
Error Recovery
  • Automatic retry on file system errors
  • Fallback to inline template content
  • Graceful handling of malformed templates
  • Detailed error logging
Performance Optimization
  • File content caching
  • Modification time checking (only reload when changed)
  • Efficient file watching with chokidar
  • Memory-efficient string processing
Troubleshooting
Common Issues
Template file not found
  • Verify the file path is relative to Node-RED working directory
  • Check file permissions
  • Ensure the file exists and is readable
Variables not substituting
  • Verify the input data structure matches your template variables
  • Check that the data is in the specified message property (payload by default)
  • Ensure you're using correct Mustache syntax: {{variable}}
File watching not working
  • Some file systems (like network drives) may not support file watching
  • Restart Node-RED if file watching stops working
  • Check Node-RED logs for file watcher errors
Debug Tips
  1. Check Status: Node status indicator shows current state
  2. View Logs: Check Node-RED debug panel for detailed error messages
  3. Test Data: Use a debug node to verify your input data structure
  4. File Permissions: Ensure Node-RED has read access to template files
Development
Local Development
npm install
npm link
# Restart Node-RED
Testing
npm test
Contributing
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Add tests if applicable
  5. Submit a pull request
MIT License - see LICENSE file for details.
Support
Related Nodes
Version: 1.1.5
Updated 1 year, 6 months ago
372 in the last week
  • file-template
  • ui
  • template
  • html
  • file
  • filesystem
  • watch
  • dashboard
  • mustache
  • handlebars
