node-red-contrib-file-nunjucks 1.2.0
A secure Node-RED node for template processing with sandboxing, file watching and multiple engines support
npm install node-red-contrib-file-nunjucks
A powerful Node-RED node for rendering Nunjucks (Jinja2-style) templates from files or inline, with support for inheritance, blocks, filters and Markdown.
✨ Features
  • 📁 File-based Templates: Load Nunjucks/Markdown templates from the filesystem
  • 🔄 Auto-reload: Watches template files and reloads on changes
  • 🧩 Template Inheritance: Full support for {% extends %} and {% block %}
  • 🧮 Logic Support: If statements, loops, macros, async tags
  • 🎯 Multiple Engines: Choose between Mustache, Handlebars or Nunjucks
  • 📊 Status Indicators: Visual feedback on file load status and errors
  • 🛡️ Error Handling: Fallback to inline templates when files are unavailable
  • ⚙️ Editor Integration: Snippets & autocomplete in Node-RED editor
  • 📝 Markdown Ready: Output remains as Markdown if needed
  • ⚡ Performance: Efficient caching and change detection
🔧 Installation
Via Node-RED Palette Manager
  1. Go to Node-RED settings → Manage Palette → Install
  2. Search for node-red-contrib-file-nunjucks
  3. Click Install
Via npm
Manual Installation
git clone https://github.com/untitledds/node-red-contrib-file-nunjucks.git
cd node-red-contrib-file-nunjucks
npm install
npm link
npm link node-red-contrib-file-nunjucks
⚠️ Make sure you have installed nunjucks:
npm install nunjucks
💡 Usage
Basic Usage
  1. Drag the File Nunjucks node into your flow (under the template category)
  2. Double-click to configure:
    • Template File: Path to your .md or .njk file (e.g., templates/incident.njk)
    • Engine: Choose: mustache, handlebars, or nunjucks
    • Data Source: Message property containing data (default: payload)
    • Output Format: Set msg.template as string or parsed JSON (if applicable)
  3. Connect your data source to the input
  4. Use output in Dashboard, Email, Debug, etc.
📄 Example Flow
        "id": "nunjucks-node",
        "type": "file-nunjucks",
        "name": "Incident Report",
        "filename": "templates/incident.njk",
        "engine": "nunjucks",
        "field": "payload",
        "fieldType": "msg",
        "output": "str"
📄 Template Syntax Examples
Base Template (base.njk)
# {{ title }}
{% block content %}
Default content
{% endblock %}
Child Template (incident.njk)
{% extends "base.njk" %}
{% block content %}
## Incident Details
- **Event**: {{ alert.event }}
- **Severity**: {{ alert.severity }}
- **Tags**:
  {% for tag in alert.tags %}
  - {{ tag }}
  {% endfor %}
{% endblock %}
Input Message
  "payload": {
    "alert": {
      "event": "High CPU Load",
      "severity": "critical",
      "tags": ["production", "server"]
    "title": "System Alert"
Output (Markdown)
# System Alert
## Incident Details
- **Event**: High CPU Load
- **Severity**: critical
- **Tags**:
  - production
  - server
🧩 Configuration Options
Option Description Default
Name Node display name (auto-generated)
Template File Path to template file (optional) none
Engine Template engine: mustache / handlebars / nunjucks nunjucks
Inline Template Inline template content (fallback) empty
Data Source Message property with template data (payload by default) payload
Source Type Where to get data from: msg, flow, global msg
Output Output format: str or parsed str
🖥️ Editor Snippets
✅ Built-in snippets for Jinja2/Nunjucks syntax:
Shortcut Inserts
block {% block %}...{% endblock %}
extends {% extends "..." %}
include {% include "..." %}
if {% if %}...{% endif %}
for {% for %}...{% endfor %}
var {{ variable }}
filter `
comment {# comment #}
📁 File Watching
The node automatically watches your template files for changes:
  • ✅ File Modified: Automatically reloads content when saved
  • ⚠️ File Deleted: Shows warning, falls back to inline template
  • 🔄 File Restored: Detects and reloads automatically
  • 📊 Status Updates: Visual indicators show current file status
🌈 Status Indicators
Color Meaning
🟢 Green Template file loaded successfully
🟡 Yellow Using fallback inline template
🔴 Red Error loading file or processing template
⚪ Grey No file specified or node inactive
📤 Output Format
The processed template is added to msg.template and includes metadata:
    "template": "# System Alert\n...",
    "_fileTemplate": {
        "lastModified": 1718000000,
        "length": 256,
🧰 Use Cases
📋 Markdown Reports
Generate dynamic reports in Markdown:
[data] → [file-nunjucks] → [debug/email/http]
📬 Email Templates
Render HTML or plain text emails dynamically:
[trigger] → [data] → [file-nunjucks] → [email sender]
📊 Dashboard UI
Use Nunjucks templates inside Node-RED Dashboard:
[file-nunjucks] → [ui_template]
📄 Document Generation
Create templates for PDF, DOCX, etc.:
[data query] → [file-nunjucks] → [pdf converter]
🛠 Advanced Features
Multiple Data Sources
Pull template data from:
  • msg - From incoming message (default)
  • flow - From flow context
  • global - From global context
Filters & Macros
Register custom filters/macros in context:
context.nj.addFilter('uppercase', str => str.toUpperCase());
Async Support
Support for asynchronous tags like {% asyncEach %}
Partials
Use {% include %} and {% import %} for reusable components
🔍 Troubleshooting
Common Issues
Template file not found
  • Check path is relative to Node-RED working directory
  • Ensure file exists and has proper permissions
Variables not substituting
  • Verify data structure matches your template keys
  • Ensure correct engine selected (nunjucks vs mustache)
File watching not working
  • Some systems (like Docker or network drives) may have issues
  • Restart Node-RED if it stops detecting changes
🔄 Fork Notice
This project is a maintained fork of the original node-red-contrib-file-template created by @DanEdens.
The original repository has been extended to support:
  • Nunjucks (Jinja2-style) templates with inheritance and blocks
  • Markdown-ready output
  • Enhanced editor snippets and autocomplete
  • Full support for modern template workflows
All credits for the initial implementation go to Dan Edens.
🛡️ License
MIT License — see LICENSE for details
🤝 Contributing
  1. Fork the repo
  2. Create a feature branch
  3. Make changes
  4. Add tests where applicable
  5. Submit a PR
📣 Support
🔄 Related Nodes
Version: 1.2.0
Updated 1 year, 5 months ago
  • file-nunjucks
  • template
  • nunjucks
  • jinja2
  • handlebars
  • mustache
  • markdown
  • sandbox
  • security
  • filesystem
