node-red-contrib-fhem 0.0.5
Connecting to FHEM instances
npm install node-red-contrib-fhem
This package contains a receiver and a sender node which connects to FHEM instances.
Requirements
a telnet "device" in fhem. https://fhem.de/commandref.html#telnet
The configured port must be accessible over the network from the node-red instance.
Example Configuration for fhem-instance
Name: MyFhem Server: 192.168.1.10 Port: 7072
Name: Temps Instance: Choose your fhem-instance
The Devivefilter and Readingsfilter are optional settings. If you leave both blank, you will get all events from fhem-instance
Example for alle temperature readings from all devices Devicefilter: leave blank Readingsfilter: temperatur
Example Configuration for fhem-out
Name: MyOutDevice FHEM-Instance: Choose your fhem-instance Device: the fhem device-name property
The string of msg.action is send directly to the fhem device "msg.action = set_on" sets a device in them on "msg.action = virtTemp 10" sets the device property virtTemp to 10
Version: 0.0.5
Updated 4 years, 3 months ago
Rating: 5.0 5
3 in the last week
  • fhem-in
  • fhem-out
  • fhem-cmd
  • fhem-instance
  • fhem
